silverado 4L60e different from regular cab to ext cab
Old Nov 14, 2010 | 04:30 PM
jay_lt4's Avatar
Default silverado 4L60e different from regular cab to ext cab
what is the differance between a silverado regular cab 4l60e and an extended cab 4l60e in the 2001-2005 range?
if you look them up on any used sites they have you select reg cab or ext cab and it gives a different interchange number?
Old Nov 14, 2010 | 04:37 PM
FLT's Avatar
FLT
The only thing that would make any sense to me is if they calibrated the separator plate a little different. As long as they are either both 4x4 or 2wd for your application you should be fine. Just make sure you specify if you need a 4x4 or 2wd. Vince
Old Nov 14, 2010 | 04:44 PM
jay_lt4's Avatar
i couldnt think of anything that would be different, but the interchange catalogs all list them as different, just looking for some parts for a 6.0L(LS3 head) / 4l60e chevy colorado swap that ill be starting over the winter
Old Nov 14, 2010 | 04:47 PM
FLT's Avatar
FLT
I say you will be fine! Good luck with the swap. Vince
