Transmission Temp. sensor?
Then i guess ill get the gears too.. Right now man i only have 255 35 17 on the rear.. It gets sideways the way it is now. Guess i will have to be carefull till i can get new rims and tires 275 front and 315 rear.. The car when i bought had some nice rims but they are only 17+8's.. cant fit a 315 on
that.
A 3500 stall+a higher STR, coupled with 3.73's will give you traction problems, and to be on the safe side I would replace the flexplate as long as you are there with a TCI SF29 unit. (it is only 3 more bolts to remove).
JMHO
SteveC
JMHO
SteveC
http://www.carcarecouncil.org/Auto_T...lexplate.shtml
SteveC
