pulling 4l60e
Old Dec 22, 2010 | 01:23 AM
z99ls1's Avatar
Restricted User
Default pulling 4l60e
So I have a few questions. I have LT headers and ORY and my ory is welded to my headers, I looked under the car the other day and it looks like there is just enuf rooms for the tranny to squeze out, but idk if I can get to all the bolts with the exhaust in the way. Any other tips while takin it out wuld be a good help. Thanks
Old Dec 22, 2010 | 01:26 AM
z99ls1's Avatar
Restricted User
Btw my question is- Can the the transmission be pulled with the ory connected to the headers?
Old Dec 22, 2010 | 01:36 AM
tording99Z28's Avatar
You should be able to pull it without undoing the Y pipe from the headers. It will be a little tight but it can be done for sure. The bolts shouldn't be blocked by much, just make sure you have a very long extension and a swivel for the bolts at the top of the bellhousing.
Old Dec 22, 2010 | 02:52 AM
z99ls1's Avatar
Restricted User
Thanks, lol I just came in from the freezing garage because I couldn't resist putting it on the jack stands and checking it out. It does look like it will be close, but im sure it won't be to tuff. Thank god I will be doing it on a lift. Hats off to those who have pulled it using jack stands lol, cuz there is no way I wuld be doing it if I had to lay on the ground the whole time. How it sits now I know there is no way I could get those top bolts out or top bolt? I know when the tranny mount/crossmember are off there and the *** end lowers down it will be doable.
Old Dec 22, 2010 | 02:59 AM
Yes if you remove the tranny mount and let the tranny/engine sag down then you can get to the top bolt or should be able too. Thats what I have always done.
Old Dec 22, 2010 | 03:10 AM
z99ls1's Avatar
Restricted User
Is ther just one bolt at the very top? I counted six, but couldn't see the very top
Old Dec 22, 2010 | 01:40 PM
z99ls1's Avatar
Restricted User
There are seven bolts in all right?
Old Dec 22, 2010 | 01:48 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
looked at a bunch of my pics,9 bolts total,5 above the locating pins,4 below.
Old Dec 22, 2010 | 01:51 PM
z99ls1's Avatar
Restricted User
Are you sure?
Old Dec 22, 2010 | 02:19 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I am almost positive there are only 7 4L60E bell housing to engine bolts.
Old Dec 22, 2010 | 04:09 PM
2 pics I have,2 different trannys
Old Dec 22, 2010 | 04:31 PM
Kevin01Z28's Avatar
The one at the top wasn't the worst imo. It was the top bolt closer to the drivers side, always makes me curse. Maybe its because I dont have a lift lol.. As long as the engine/trans can sag to give you some clearance the y-pipe shouldn't be a problem but I have always removed it.
Old Dec 22, 2010 | 05:17 PM
Jays_SSZ28's Avatar
There are eight bolts holding the bellhousing to the engine. The transmission isn't going to move enough with the exhaust installed. The exhaust will hold the trans up and you'll never get that top bolt.
Old Dec 22, 2010 | 05:38 PM
z99ls1's Avatar
Restricted User
I guess I will have to try it and if it wont come down than I will have to cut it. Where would be the best spot to cut the ory. I don't wanna cut close to the headers cuz that makes me nervous lol
Old Dec 22, 2010 | 07:38 PM
Jays_SSZ28's Avatar
I'd cut it nice and square and use butt type (not overlapping) band clamps to put it back together.
I have three of these on my Y and can drop the whole thing out.
Old Dec 23, 2010 | 01:33 AM
z99ls1's Avatar
Restricted User
One says seven, one says eight, and one says nine lol. It does look like ther are nine in the pic he posted above.
Old Dec 23, 2010 | 09:14 AM
Jays_SSZ28's Avatar
I've had enough LS1 transmissions out to know
How many bolt holes do you see?
Old Dec 23, 2010 | 09:58 AM
^^^ I would have to agree with the above pic.
even though the pics I put up were of the trannys,one of the holes could be for a different application. threaded holes in the block are indisputable.
Old Dec 23, 2010 | 11:37 AM
z99ls1's Avatar
Restricted User
Ha, thanks alot guys
Old Dec 23, 2010 | 11:44 AM
z99ls1's Avatar
Restricted User
You have been right to much on here. I hope your wrong on this one lol. I really don't wanna have to cut my exhaust
