What trans.cooler?
Old Dec 30, 2010 | 11:18 AM
'01-B4C's Avatar
Default What trans.cooler?
OK guys, I've decided on my new trans. and 3600 stall, so now I need to know what cooler you guys are running to keep temps. under control. Any brand better than others? Any fit better? Thanks in advance. Post up what you are running and where's the best place to get em.
Old Dec 30, 2010 | 01:39 PM
'01-B4C's Avatar
already tried a search thank you...I was looking for opinions on which ones people were running and their results ...ie...any trouble out of a particular one
Old Dec 30, 2010 | 02:37 PM
SilverSS07's Avatar
I've got an Earl's cooler in my Monte. Keeps her right around 180.
Old Dec 30, 2010 | 02:56 PM
z99ls1's Avatar
Restricted User
http://www.summitracing.com/parts/BMM-70264/
That one is the one I just installed. It comes with the kit and makes the install easy. It will work good for ur 3600 converter. I am going to be using it with my 3400 stall and it is a very common cooler peope use
Old Dec 30, 2010 | 05:46 PM
JoshuaGrooms83's Avatar
Would something like this be ok with a 3000-3200 ranged TC with a DD car on stock gears and relativly stock HP numbers?
Old Dec 30, 2010 | 06:27 PM
z99ls1's Avatar
Restricted User
I don't think so. That thing is tiny
Old Dec 31, 2010 | 01:54 AM
z99ls1's Avatar
Restricted User
Originally Posted by senicalj4579
I have the b&m 14400 btu. Highest temps iv seen was in 180s after beating on it a little and sitting still afterward in drive through. But this is with the stock stall. Also, those temps were not even taken in the middle of hot summer. So I maybe looking to another setup after the higher speed stall goes in idk yet. But in this 30 degree weather temps were 130s mostly. Now the car is in hibernation lol. Cant wait for spring
Like I said ..."get the biggest one you can fit" which should be AT LEAST the size I have and you should be good
Makes me wonder if I should have went a little bigger
Old Dec 31, 2010 | 03:02 AM
Even if its almost 2ft long?
Old Dec 31, 2010 | 03:13 AM
z99ls1's Avatar
Restricted User
A little wider would help it catch air I think. Im not a cooler expert though, so hopefully someone can answer that for you
Old Dec 31, 2010 | 03:27 AM
01ssreda4's Avatar
B+M 70264 or 70274
Old Dec 31, 2010 | 06:30 AM
Cold06's Avatar
Originally Posted by 01ssreda4
B+M 70264 or 70274
X2 B&M all the way FTW!
Old Dec 31, 2010 | 10:49 AM
redbird555's Avatar
B+M 70264 or 70274
This is the one ive got 29,000 btu my tranny pan is cool to the touch bafter hard runs in the south fl heat although i still have the stock stall but its still a badass cooler!
Old Dec 31, 2010 | 06:44 PM
'01-B4C's Avatar
redbird....how do you have the 70274 mounted? can it be "doped"
Old Dec 31, 2010 | 07:41 PM
senicalj4579's Avatar
Biggest you can get doped is the one I have. 70264
Old Dec 31, 2010 | 08:16 PM
sheikss's Avatar
I got the b&m 70297, I wish I would have went with the 70298. It was a real pain mounting it up.
Old Dec 31, 2010 | 09:00 PM
jsteele90's Avatar
i have the 70274 its a massive cooler. almost too big. i still havent found a decent place to mount it where it gets good air flow cause i have a fast toys ram air on my car.
Old Jan 1, 2011 | 11:24 AM
01ssreda4's Avatar
Nope, see below
He is right
It is big, I wouldn't recommend it for anyone running the Fast Toys set-up. There just isn't enough room in front of the radiator.
Old Jan 1, 2011 | 11:52 AM
'01-B4C's Avatar
Yea the guys at RPM reccomend the 70297, but I was just wondering where to mount. Does the fan push or pull? Just wondering if it would be workin against the radiator fans if mounted in front of rad. I don't know if I'll go with it if I can get by with the smaller one dope-style and still cool adequately. Any thoughts?
Old Jan 1, 2011 | 12:37 PM
slow67's Avatar
Gingervitis Addict
I have the 70274 mounted "dope style" under my passenger side fog light (Camaro).
Old Jan 1, 2011 | 04:12 PM
redbird555's Avatar
I dont have the ram air in mine but ya i have mine mounted in front of the rad and it works out fine!
