Help ID'ing this 4L80e?
Old Jan 3, 2011 | 07:56 PM
evo462's Avatar
Default Help ID'ing this 4L80e?
Besides the fact it's dirty!
I know there's small nuances different between the years, just wondering if those with a sharp eye had any info on it. I was told it was behind a SBC in a "street rod" - but given the level of dust on it, maybe it was a street rod in need of a restoration.
I had read the "earlier years" had the cooling lines on the side?
Old Jan 3, 2011 | 08:19 PM
Camaroz's Avatar
97+ 4l80E have the cooler fittings seperated. One near the bellhousing and one near the tailshaft end.
Old Jan 3, 2011 | 08:25 PM
evo462's Avatar
Is there a benefit/drawback to the relocated cooler fittings? So it's somewhere in the 91-96 range most likely?
Old Jan 3, 2011 | 08:43 PM
Camaroz's Avatar
IIRC Better Cooling/Lubrication. But 2000+ Years had stronger hard parts etc... That's what you really want just. Add a TransGo and have a pretty damn strong trans for just a shift kit.
Old Jan 4, 2011 | 10:51 AM
Jays_SSZ28's Avatar
It's a 1993. The yellow tag on the side says 93. Plus it still has the old style electrical connector.
Old Jan 4, 2011 | 03:23 PM
forcd ind's Avatar
yep, the tag says 93
Old Jan 4, 2011 | 03:34 PM
evo462's Avatar
I assume a Speartech adapter has a model for both style plugs?
Old Jan 4, 2011 | 03:45 PM
slow67's Avatar
Gingervitis Addict
Not likely, just update the solenoids/internal harness to the new style.
Old Jan 4, 2011 | 05:26 PM
Camaroz's Avatar
I'd personally just get a 2000+ 4l80e much easier I'd say plus updated/stronger internals. Why not just sell the 93 Trans?
Old Jan 4, 2011 | 05:52 PM
Jake's Performance's Avatar
Actually the early style units have a better OD sprag design, and all the" improvements" didn't seem to help from what I've seen tearing down hundreds of cores.
Old Jan 4, 2011 | 06:05 PM
Camaroz's Avatar
I won't fight you on that! You are the expert. That's just what I've been told a million times
Old Jan 4, 2011 | 06:17 PM
I don't have a problem using any year model core, on big power builds I always use the early OD parts even on a late unit.
The improvements GM did seem like a good idea but in practical application I haven't seen any real difference.
Old Jan 5, 2011 | 05:56 AM
Vince B's Avatar
Moderator
I agree with this statement the only issue I have seen is on the first or second years of this unit. The OD planet in some cases does not have any lube slots in the planets spline area. Also I ran into an issue with the input shaft not fitting into the later assemblies. For what I could tell the first year of shaft and planet assemblies were just a bit different and I had an issue with getting the snap ring on when swaping stuff around. I would make sure to use an OD planet with at least two slots in the planet for any unit in my opinion. Vince
