Recent Trans Problem
Old Jan 9, 2011 | 11:52 PM
Mpham2011's Avatar
Default Recent Trans Problem
My 4l60e Trans is sluggish from start
reverse made a pop couple days ago and now only loads engine and rolls forward in reverse
goes forward in neutral
also either 1-2 gear slip or 2nd isnt there
firebird goes 2500 rpm at highway speed (no 4th gear?)
rpm's jump in turns like it's not in gear
Old Jan 10, 2011 | 07:05 AM
72blownvert's Avatar
Sounds like the foward clutches are welded together.It needs to come out for a rebuild.
Old Jan 10, 2011 | 09:47 AM
performabuilt's Avatar
LS1Tech Sponsor
I would concur internal failure you need to replace or rebuild the trans
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 10, 2011 | 11:31 AM
Mpham2011's Avatar
how bad would it be to drive it the way it is? what would be the longevity if i did
Old Jan 10, 2011 | 03:46 PM
ArkBird96's Avatar
The more you drive it like that, the more damage you're doing to it and the more $$$ it will cost to fix. Better to re-build now in my opinion.
Old Jan 10, 2011 | 11:55 PM
Mpham2011's Avatar
found a used one near my area http://madison.craigslist.org/pts/2148914760.html probably cheaper to buy this one and have it installed at transmission shop?
