How to install a torque converter
I have had the best luck by putting trans jack up tight but not lifting trans and motor, just tighten it up, then remove cross member, lower it enough to get top bolts out or in, then raise it back to the highth were it sat on cross member. Now, put a small vertical jack under oil pan with a thick wide board to keep from damaging pan. Now you can take out the rest of the bell housing bolts and converter bolts or put them in. So when you are lifting the trans back in, everything is level. When putting them in, put just the two bolts in each side of bell housing, align converter, bolt it on. Trans should go up against block fairly easy sense you put the jack under oil pan. This will give you two different ways of adjustments if needed. One with the trans jack and one with the block if you need any at all. When converter is on you can now take the jack out from under the block and let trans down a little to be able to reach top bolt to bell housing much easier. Also getting the mount that holds the breather hose goes on the top bolt as well. Put dip stick in then the fluid lines because lines are always in the way if you put them on first before dip stick. At least they are for me. Hope this double jack method helps to align a little easier.
