convertor install question
Old Feb 10, 2004 | 09:17 PM
68ragtopLS1's Avatar
Default convertor install question
I'm right in the middle of installing a TCI streetfighter. I slid the new convertor on and I believe I heard the 3 splines engage. The convertor spins freely and sits back a good half inch inside the trans housing. When I went to bolt the trans back to the motor, I got it lined up good but when there was still about a 1/8 inch gap between the trans and the motor the convertor was tight up against the flywheel. I have not gone any further with it. I thought there was supposed to be a small gap between the convertor and the flywheel when the trans and motor were bolted together tight. Am I wrong about this? What should I do next. I don't want to break the pump or anything else. Thanks for any help you can give me. John
Old Feb 10, 2004 | 09:20 PM
LS1INSIDE's Avatar
Same thing happened to me when I was installing my friends verter, so I just took it the tranny back off and converter off and tried it again. make sure you hear those distinct clicks.
Old Feb 10, 2004 | 09:24 PM
chrismcdaniel's Avatar
i just posted looking for a write up on installing a TC. It just so happens that im gong to be installing the TCI 3500, So please post when you figure this out, and let me know of any other pit falls you run into.
Old Feb 10, 2004 | 09:35 PM
2xLS1's Avatar
Before you put the tranny back in, lay a straight edge across the tranny housing flange and measure from that surface to the T/C mounting lug. It should be 1.125 inches. And yes, you should have to pull the converter back up to the flywheel slightly with the tranny case flush against the engine.
Old Feb 10, 2004 | 09:49 PM
http://modernmusclecars.net/articles...all/index.html
This write up says 1.0 inches, are you sure that its 1.25? Not that I know either way, im just trying to gather as much info as I can before I start mine, and I want to make sure its strait.
Old Feb 10, 2004 | 10:15 PM
2xLS1's Avatar
Look closer. I said 1.125 inches which is 1-1/8. I think the +- tolerance is .050 but not 100% sure on that. All the ones I've done, and I've done a lot, are right at 1-1/8.
Old Feb 10, 2004 | 10:37 PM
cool, thamls for clearing that up for me. i just realy dont want to mess this up ya know.
Old Feb 11, 2004 | 12:16 PM
LS1INSIDE's Avatar
Just follow the write up, they pretty much got it, but like I said just make sure you have enough clearance.
Old Feb 11, 2004 | 05:58 PM
Thanks guys. I'll drop it back down and try again.
Old Feb 13, 2004 | 12:54 PM
I dropped the tranny back down. I took the converter back off and slid it back on. I heard the 3 clicks and I am 100% sure it is seated all the way back. I put a straight edge across it and I still only get 1/2 inch inside the housing. I pulled it back off and took a bunch of measurements and I don't see how it could go back any further. I tried putting the stock converter back on and it was the same way. I don't know what else to do. Should I try to bolt it together?
Old Feb 13, 2004 | 02:48 PM
2xLS1's Avatar
No. Keep trying. If you do not have 1-1/8 inches from the bell housing flange to the front surface of the T/C mounting lug, it is not on all the way. You will damage the pump if you force it on. Try wiggling the converter up and down while turning it and pushing it on.
Old Feb 13, 2004 | 03:32 PM
I got it. I just had to swear at it a few more times. It measures 1 1/8. Thanks for all the help. John
Old Feb 13, 2004 | 09:02 PM
LS1INSIDE's Avatar
Default good job!!
there ya go!
Old Feb 13, 2004 | 10:26 PM
so, why wouldnt it go on all the way the first 3 times?
Old Feb 14, 2004 | 07:51 AM
The last spline must not have quite been in right. I scribed a line on the front of the converter that faces you when trying to put it in parallel to the 2 notches that you have to line up. Before putting it back on I looked in the trans to see how it needed to be orientated. It took me a few minutes and it finally lined up right.
