can anybody tell me Driveshaft Length for a 4L80 and stock 10 bolt 2001 Camaro
Just getting ready for my transmission swap...
need to know these 2 measurements
![](http://www.spohn.net/prodimages/1640/401.jpg)
can anybody tell me what measurement A is for a 4l80 and the stock 10 bolt in a 2001 Camaro?
Just trying to get measurements so I can have the driveshaft here when the transmission shows up to make it a one day install for me.
If I told you a solid number would you order a driveshaft off that?
If you did you might not only be looking at a more than one day install, you might be looking at buying two driveshafts.
Get everything installed, measure, then order.
I've seen this question too much. What length DS for X transmission in X vehicle with X rear.
honestly
I believe I know what the length should be.
just looking for somebody who has done it to confirm that the # is correct.
you dont have to be an *** about it... you could have just went on about your business and ignored this like I do to so many posts that I dont feel I need to answer myself.
honestly
honestly
I just recommended measuring off your set up rather than taking the chance of buying two driveshafts. Seems like good advice to me.
Agreed,
And the first post by "slow67" was correct, a T56 or 4L60 driveline will work for a 4L80 conversion.
