th400 cluth engagement wires
Old Feb 15, 2004 | 08:13 PM
69firebird's Avatar
Default th400 cluth engagement wires
I am swapping from a m6 to th400 I was wondering what wires on the clutch pedal that you cross to make it start?
also, I have a switch panel, and a empty switch I was wondering if I ran the wires couldnt I just use the switch like the stockish setup??
thanks
ed
firebird455@onebox.com
Old Feb 15, 2004 | 08:29 PM
DERTY's Avatar
The Bull
You splice the lower clutch switch wires into the neutral safety switch ot make it start. Reverse lights are a different story. Sorry, I got a little confused with your question about the switch panel. What are you asking about?
Old Feb 15, 2004 | 09:39 PM
69firebird's Avatar
the shifter that I have doesnt have the neutral saftey switch.
So I was wondering if I could just run the wire to a panel where I allready have switches?
I dont really care about the NSS, so I was wondering the switch panel is allready in place.
also is there only one wire down there by where the clutch pedal plugged in? I honestly dont remember
thanks
ed
Old Feb 15, 2004 | 09:49 PM
DERTY's Avatar
The Bull
You could just take the plug out of the sensor and just splice them together. Be smart and don't hit the starter while it's running (I know, duh)!
