Trans Fluid Temp Gauge
A mechanical sender in a sheet metal pan is going to need an adapter brazed in. Brazing on the pan can be tricky because it will want to crack when it cools. Every mechanical gauge adapter fitting I have seen is brass so it has to be brazed.
The advantage of an electric gauge and sender is that it has a much smaller sender. With this sender you can screw it into the pressure port, install it in a drain fitting which requires a hole drilled in the pan and the fitting installed with a nut.
My personal preference is to use a tee in the cooler line going to the cooler along with an electric sender. Or have a drain plug tig welded into the pan and use it for the electric sender.
BTW, for people who are running a trans temp gauge, what does your temperature normally run? I live in east TN and the other day was the first time I had the car out, it was about 55 degrees outside. I was expecting temperatures to run anywhere from 160-180. The car barely hit 150 once on a long uphill pull with the converter turning about 3000 for close to a minute.. Anything sound funny about this??
Or you could put the sender in the case pressure port, I personally don't like it there but thats me I guess.
