No Over Drive (4th Gear)
thanks
shane
Hope this helps,
Josh
shane
I can't say 100% that the servo gasket is your problem but it sure sounds like it. You really don't have to take it all apart again(tranny pan and valve body I mean) all you have to do is remove the cover off the servo on the passenger's side of the tranny. You will need a medium sized pry bar and a flat head screwdriver. And the gasket kit was around 5 dollars. Just go to a tranny shop and tell them that you need the servo gasket set.
It is a PITA to remove and reinstall the cover but you can do it. If you don't have access to a lift then put the car up on jackstands.
Good luck,
Josh
I had the same problem and it ended up being my 3-4 servo was frozen.
You may need to replace your entire servo like I did.
shane
