What stall and size converter for DD
Old Jun 5, 2011 | 11:15 PM
1fastirocz's Avatar
Default What stall and size converter for DD
I'm going to order a PereformaBuild level 2 4l60e for my camaro. I drive the car a lot and take it to the track a few times a year. I'm going to get a PereformaBuild converter to. I don't really know what size converter I should get 9.5 or 10.5? I was thinking a 3200 or maybe a 3600 stall would be good but I'd like to see what everyone thinks. The car has full bolt on's now, I have 3.73 gears that will being going in latter, I plan on doing a cam swap this winter. What do you guys suggest? Thanks
Old Jun 5, 2011 | 11:19 PM
lemons12's Avatar
Plan on spraying? 3200 is too small..3600 minimum.
If you are staying all motor, 4000.
Old Jun 5, 2011 | 11:24 PM
1fastirocz's Avatar
Probably going to stay all motor for now.
Old Jun 6, 2011 | 05:41 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
https://ls1tech.com/forums/automatic...-dd-stall.html
Old Jun 8, 2011 | 01:27 PM
Mystery Bird's Avatar
I just had mine reconfigured from 3000 to 3600, with normal driving I barely notice it. On the track it is a different story, big difference. I'm wondering if I should have went with a 4000.
Old Jun 8, 2011 | 02:29 PM
dannyz's Avatar
Ha ha, same here.
I had a 3000 stall in my car for about 6 years and thought it was great.
Put in an flt lv 4 trans along with a Yank SS3600 stall and was astounded that there was NO noticeable difference in daily driving.
My 60' dropped from a 1.76 down to a 1.64 at the track.
As Lemons said, 3600 if your gonna spray, 4000 if not.
Old Jun 8, 2011 | 03:10 PM
lemons12's Avatar
I try in all these DD stall threads to explain there is virtually no difference in a 3400 vs 4000 converter around town but wot is a huge margin.
Nobody usually listens and is scared 4000 is to big and goes with a 3600.
