What stall for ms3
Old Jun 12, 2011 | 10:01 PM
Rpayne41985's Avatar
Default What stall for ms3
What stall and gear for ms3 cam. pretty much drag with little around town riding. Want all I can get from cam only.
Old Jun 12, 2011 | 10:08 PM
01ssreda4's Avatar
4k stall IMO.....
Moving to AT.
Old Jun 12, 2011 | 11:58 PM
T AM's Avatar
4.10 gears would be sweet, since you said it is mostly a drag car with some city driving.
Old Jun 13, 2011 | 01:19 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
2nd the 4K range
Old Jun 13, 2011 | 09:16 AM
regblkss's Avatar
Yank SS 4000 and 3.73
Old Jun 13, 2011 | 03:57 PM
jpajkos's Avatar
Circle D 4400 stall and a set of 4.11s.
Old Jun 13, 2011 | 10:22 PM
WS6tx's Avatar
4K would work nicely for ya
Old Jun 13, 2011 | 10:30 PM
MYSTIC-1SC's Avatar
I agree a 4000 would be a nice choice. When i was MS3 cam only i was closer to a 4400 converter and they worked great together!
Old Jun 15, 2011 | 01:08 AM
Gunrock_T/A_0811's Avatar
I have a circle D 4C 3800 stall going in with my MS3, talk to Chris Sehorn at circle D he will give you what you need for what your application is. Circle D was way nicer and had way better customer service than anyone else I talked to.
Old Jun 15, 2011 | 01:26 AM
CUR4VNM's Avatar
4000-4400 with 4.10's for how you're describing where you'll mostly be driving it.
Old Jun 15, 2011 | 03:36 AM
GasHouseGorilla's Avatar
was searching for someone who had an MS3 cam and came across this thread. Don't mean to hijack it, but I recently purchased a car that came with a mvb 4l80e/small stroker ls1/ms3 cam/317 heads on 3.23's (just got the car) with a yank 3400 nitrous converter and was wondering the same thing. the car will be bottle-fed soon and has a solenoid lockup...car will be driven probably around a hundred miles or so a week and occasionally track-ran. hopefully rpayne doesn't mind and we can both get some more answers. thanks a lot.
Old Jun 16, 2011 | 12:56 PM
Texas Speed recommends at least a 3600 for the MS3 I believe. I talked to Chris at Circle D specialties about mine, same setup minus the stroker, and that I would be spraying at least 200 in the car. He suggested a 3800 stall, 4C is circle D's model that I went with. On the bottle it will flash around 4500. Look on the right for one of the sponsors, Circle D is one, don't know about the others and ask them to make you something for your needs.
Old Jun 16, 2011 | 05:55 PM
z99ls1's Avatar
Restricted User
I would def go 4k plus with that big of a cam
Old Jun 17, 2011 | 12:39 AM
thanks for the replies fellas. i really thought that the converter setup wasn't going to be ample enough for how the car is built, and after somewhat researching similarly-modified LSx's, it was definitely made clear that something has to be done in the way of getting a bigger stall on this damn thing. obviously i'm going to afford myself some other things parts-wise in the process and although i would really like to get this issue out of the way this season, the cash flow simply does not permit for it all to be done at once...need a whole new setup for the rearend and axle (still on the stock a4 3.23 10-bolt) if I ever plan on actually trying to get this thing out from a dig on a decent sized tire, SFC's, and a small shot comparative to what i could be spraying at the thing...that being said, I'm guessing I would be able to sell some of the parts I'm getting replacements for since they are all in really good shape and have relatively low mileage on them, but i certainly know im not walking away with anything on the cheap cheap. less money, mo problems. ha. thanks again and if anyone feels they would like to help a relative lsx newbie with any tips or advice, then, by all means...
Old Jun 17, 2011 | 12:46 AM
AHHHH! real monsters i almost forgot to ask: does it matter that the converter was an fi/nitrous converter? i feel like the thing is very, very tight and that with more power or a shot it would loosen up some? does this make any sense?
