4L80E output shaft question
Old Jul 2, 2011 | 08:21 AM
LTX355's Avatar
Originally Posted by Jake's Performance
I would rethink that a bit. Why do you think a bevel isn't needed? Why would they add that as a machinining operation during the manufacturing of the yoke if it wasn't needed?
Would you still think the same thing when I voided your warranty on a transmission that had thrust washer damage?
as long as the shaft is able to slide in and out with ease i dont think it would cause wear on thrust washers unless it was binding.
Old Jul 2, 2011 | 03:30 PM
Jake's Performance's Avatar
Cutting it with a hacksaw or by other means without the bevel will allow it to bind.
Just because it travels freely by hand on a bench doesn't come close to simulating the real world stresses while it's in a vehicle.
Old Jul 3, 2011 | 02:09 AM
Vince B's Avatar
Moderator
I'm going to fully agree with this statement. But hey you can lead a horse to water....
Old Jul 3, 2011 | 10:51 PM
mike13's Avatar
That's not true. I'll hold his head down and you suck on his ***.
Old Jul 4, 2011 | 11:07 AM
Vince B's Avatar
Moderator
How bought we do that the other way around?
Old Jul 14, 2011 | 01:50 PM
quicksilver383's Avatar
There are two places the yoke can bottom out. Cutting the end of the yoke wont help if the output shaft is bottoming out inside the yoke.
