45* -6AN fittings don't fit off trani?? Help!
Just had to figure this out myself...you need -6 AN to 1/4" NPT adapters for the transmission, then connect them to 45* -6 AN fittings, then run -6 AN line to your transmission cooler. Transmission coolers with 1/2" NPT seem to be the most common that have readily available adapters to connect to the -6 AN line. You'll need two -6 AN to 1/2" NPT adapters for the transmission cooler.
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
