Heat wave. How's your trans temp?
Old Jul 21, 2011 | 06:54 PM
HuggerOrangeZ's Avatar
Default Heat wave. How's your trans temp?
Hit 100 here in NW Ohio today just wanted to see what everyone else was seeing on their trans temp gauge.
On my Aeroforce Interceptor the IAT was going back and forth from 100-102 degrees and trans temp stayed steady at 199 degrees, hit 201 once for a little bit.
Most I have ever seen on the gauge was 210 when I was driving it hard.
Old Jul 21, 2011 | 07:11 PM
LS6427's Avatar
Do those laser temp gauges work? Like if I pointed it at the metal line where it exits the case from the trans to the coolers?
Old Jul 21, 2011 | 07:16 PM
babbage1109's Avatar
Mine stays cool with my trans cooler
Old Jul 21, 2011 | 07:28 PM
The laser temp gauge could probably give you a good idea but won't be exact I would think.
How cool is cool? I have a trans cooler too and I didn't think 199 was too bad for 100 degree air tempurature.
Old Jul 21, 2011 | 07:32 PM
LS6427's Avatar
What cooler(s) do you have?
Where they mounted?
I have this pictured below. Then I also just put a brand new tranny in this weekend with a second 30 row stacked cooler on the other side mounted the same way.
Attached Thumbnails Heat wave. How's your trans temp?-dsc01781.jpg   Heat wave. How's your trans temp?-dsc01784.jpg
Old Jul 21, 2011 | 07:42 PM
senicalj4579's Avatar
90f here in ct thats pretty warm for around here. Beating on my stalled auto city, highway, for a total of an hour straight driving time. Trans temps 165f-180f. Keep in mind these temps read off the OBD port so the temps are probably a little lower than if it was an aftermarket setup. Coolant temp is efficient as hell after taking the ac condensor out stays 194f-203f with stock t stat.
My setup...20k GVW fin and tube trans cooler mounted right on the radiator with a SSRA right in front of it. "PERFECT" street car setup IMO.
This is what it looked like before I took the condensor out. Now I have the cooler mounted on the radiator.
Old Jul 21, 2011 | 07:46 PM
GT Griller's Avatar
I have 2 coolers in front of the radiator, in 100+ degree weather car runs at 170-180ish.
Old Jul 21, 2011 | 08:05 PM
Dang 180 in 100+ degree heat!? I should get one of those inline coolers to help mine out.
And my coolant was at 199, most I have ever seen. It's usually 190-194.
Old Jul 22, 2011 | 09:01 AM
If you need a transcooler I have 3 to choose from. Do a search in FS section.
Old Jul 22, 2011 | 09:18 AM
LeanPocket's Avatar
lol i was in ohio 2 weeks ago to catch my fiance's brothers wedding, I live in deep south texas, and I was literally sweating like no mans bidness. I left texas to beat the heat, and i ended up worse off then before i left texas
Anyways, I deal with 100+ heat index's 10 months out of the year and my auto tranny is fine. Although I don't weekly race my car either I just DD it
Old Jul 22, 2011 | 03:57 PM
I already have a trans cooler just thought one of these would help it stay cooler.
http://www.google.com/products/catal...d=0CFwQ8gIwBA#
Old Jul 23, 2011 | 02:58 AM
Boman6760's Avatar
I'm also NW Ohio. And yes this heat sucks! My trans never broke 200 all week. Single cooler in front of radiator, 3600 stall, reading temp from the pan. I was watching it though for sure.
Old Jul 23, 2011 | 09:04 AM
KRAZY K 2000 TA's Avatar
130 degress
Old Jul 23, 2011 | 10:55 PM
Update for my temps. Hottest day ever on record yesterday here in CT. Trans temp got to 190 after beating on it. Wouldnt go any higher though. It was 103f and my iat was 110f coming through the ssra.
Old Aug 16, 2012 | 02:39 PM
Siciliano15's Avatar
did you say you have an aux cooler? my aeroforce gauge after driving around on a hot day has gotten up to 205º to even 210º but i use the stock radiator cooler and have a yank ss3600 with stock 3.23 gears. then when I get on the highway and the converter locks up it pretty much stays at that temperature for at least 10 minutes until eventually making its way down to around 200º. I dont know why but even if i hop on the highway when cold, the converter will be locked but the temps still creep up into the 180-190 range when its hot out. I have a 160º thermostat but the car runs at around 185º in the heat.
Old Aug 16, 2012 | 02:50 PM
underpressureWs6's Avatar
Hottest mine ever went with a cooler was 205 in almost dead stop traffic in 100 degree weather. but normally stays around 170
Old Aug 16, 2012 | 04:12 PM
mjs1012's Avatar
the converter causes more heat. youre going to want an aftermarket cooler on the car to keep temps down. i have the same setup as you (ss3600 w/ 3.23s) and with my cooler, the highest i see is 180 on my aeroforce gauge when im only beating on the car.
Old Aug 16, 2012 | 05:58 PM
oh thats a big difference. once the temps go up though do u find that when you go on the highway it takes a while for temps to show that they are going back down or is it instant?
Old Aug 16, 2012 | 06:42 PM
mjs1012's Avatar
It doesn't take long. Like if I drive like 5 minutes on the highway locked up it'll start to go down pretty quick. The stock cooler gets temps up quick and usually keeps them there, aftermarket coolers don't get up to temp as quick and have an easier time cooling the trans.
Old Aug 16, 2012 | 11:07 PM
Lee12609's Avatar
everyone should post whether or not they are going through the radiator cooler then aux cooler or bypassing radiator.
to me running through the radiator is what makes most of you run in the 180-200° range.
3200 stall, 105° outside, 187° transmission fluid temp (logged), through radiator cooler first.
