torque converter for my cam.
Old Aug 6, 2011 | 12:17 AM
aAZz's Avatar
Default torque converter for my cam.
Ok guys I'm finishin up my swap on my nova. Now my original plan was 2 use the stock converter. Now I've been reading a lot and thank you guys for the valuable information. Now my cam is a pat g cam 234/246. I'm also using stock 706 heads. My funds are very low and I kno most will recommend a 4k stall but like I said no funds. So my question is what's the cheapest stall I can go wit. I don't mind driving the car even if it doesn't have great street manners. Thanks
Old Aug 6, 2011 | 12:24 AM
01ssreda4's Avatar
Your cam is a 234/246? Cheapest thing I would recommend is a restalled stocker from Yank or Circle D, or a 9.5 inch from PTC. 3000/3200 would be the minimum I would recommend.
Old Aug 6, 2011 | 12:36 AM
aAZz's Avatar
I've heard of restalled stock converters. How much does that usually run?
Here the cam card
Sorry about wrong section
Old Aug 6, 2011 | 02:00 AM
01ssreda4's Avatar
All the options I listed above would be about $400 give or take.
Old Aug 6, 2011 | 07:09 AM
aAZz's Avatar
I should of thought of that before the cam lol
Old Aug 7, 2011 | 07:19 PM
aAZz's Avatar
Ok so I have a little more room 2 work with I have around 400 for a stall. What do u guys recommend?
Old Aug 7, 2011 | 07:39 PM
senicalj4579's Avatar
Whatever you do just dont cheap out on a stall. Just get a couple hundred more bucks and get a 3600-4000. Isnt that kind of a big cam to go below a 3600?
Old Aug 7, 2011 | 08:02 PM
aAZz's Avatar
Idk anythin about stalls honestly. That's why I'm coming 2 u guys
Old Aug 7, 2011 | 08:06 PM
KevinR's Avatar
I'm with senical on this one. Spend the extra money for a new one (if you have it). Go with a 4000 for that cam.
Old Aug 7, 2011 | 08:21 PM
aAZz's Avatar
What stall do u guys recommend?
Old Aug 7, 2011 | 08:23 PM
KevinR's Avatar
Yank and Circle D are at the top of the list for a lot of people. Call one of them and they will get you set up. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >
Old Aug 7, 2011 | 10:32 PM
01ssreda4's Avatar
I would think a 4k would be a pretty nice match up for that cam. You can call Dave at Yank or Chris at Circle D and get their recommendation.
Old Aug 8, 2011 | 10:04 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Yeah that cam is going to need a good 3800-4000 stall. That car will be a turd with a stock type converter and probably wont even idle unless you have a fairly loose converter. I would give Chris at Circle D Specialties a call at 713-895-8834. He can fix you up and provide you with several options.
