th400?
Old Aug 7, 2011 | 02:26 PM
bonnarls1's Avatar
Default th400?
i have a 2000 firebird with a th350 in it i just pick up a th400 what do i need to swap it? thanks joe
Old Aug 8, 2011 | 06:30 AM
bonnarls1's Avatar
anyone need to start getting some stuff together
Old Aug 8, 2011 | 06:54 AM
SuperSlow02's Avatar
Shouldn't need anything since a th350 is in it.
Old Aug 8, 2011 | 08:42 AM
bonnarls1's Avatar
crossmember and drive shaft are the same?
Old Aug 9, 2011 | 03:00 PM
I'd think they are but, better off measuring the length of the transmissions. Some come short and some are long.
Old Aug 9, 2011 | 03:03 PM
As for the crossmember you can check BMR suspension and just look at the conversion crossmembers. I think they are the same too
Old Aug 9, 2011 | 05:49 PM
camaro_five0's Avatar
You'll need a new drive shaft yoke (they are not the same), cross member, tranny mount, and a kickdown wiring harness since the kickdown is electronic instead of cable-actuated. That's about it I think.
Old Aug 9, 2011 | 06:29 PM
JL ws-6's Avatar
Race your car!
You will need:
Crossmember, as they are different.
Driveshaft, may be a different length, I haven't done this swap so I'm not 100% on that
If you have a rmvb, you may need a different shifter.. if it's a std valvebody, you're good.
There is no "kickdown" crap needed at all if it's got a manual valve body.. which I couldn't imagine it not to have a manual one.
Old Aug 10, 2011 | 07:14 AM
bonnarls1's Avatar
Originally Posted by JL ws-6
You will need:
the th350 in it now has rmvb already so the shifter should work
Old Aug 10, 2011 | 09:29 AM
JL ws-6's Avatar
Race your car!
Correct, if the th400 has the same type of valve body, then it's just the crossmember, and driveshaft that should be needed.
Old Aug 10, 2011 | 10:08 AM
bonnarls1's Avatar
thanks jl
Old Aug 10, 2011 | 10:19 AM
UMI Performance's Avatar
Yes cross-member is correct, how are you mounting your torque arm now with the TH350?
Old Aug 14, 2011 | 07:25 AM
bonnarls1's Avatar
tunnel mount
