4.3L 4l60E question... will it work?
Hey guys i have come across an 07 4.3 van 4l60e... will it bolt to a 5.3?
It has the 12 oclock bolt hole, and 6 bolt tail housing.....
are they the same as the fbody trans (minus the torque arm mount)????
Thanks for any help guys!!!
i bolted this same transmission to my 6.0. But you will need a hughes or similar crank spacer with your flexplate. you will also have to elongate the converter bolt holes a little inward for them to fit.
But i just had to pull the trans because the input shaft broke due to too much power. but the trans was completely built. this time im putting in a hardened input shaft, it will be worth the money.
