Help Funky Sound from TQ Converter
Old Mar 5, 2004 | 02:01 AM
offaxis's Avatar
Default Help Funky Sound from TQ Converter
Hey guys
I have a funky sound in my tq converter. When I put the car up on thelift is sounded like there is a bolt or something flying around in the converter. Everything is working fine stalls up and all. I checked the fluid and it is perfect too.
Any ideas? anyone ever hear of anything like this?
I have a Vig 4000 multi disc converter
Old Mar 5, 2004 | 07:23 AM
BAIN's Avatar
Maybe a balancing weight came off?
Old Mar 5, 2004 | 08:31 AM
jimmyblue's Avatar
Moderator
Or your POS late-model flexplate has cracked a web,
as others have.
Old Mar 5, 2004 | 01:56 PM
offaxis's Avatar
as others have.
I have already replaced mine once . I took down the starter and looked as much as I could at the flywheel . It looks intact unless it is cracked around where it bolts to the crankshaft. I couldnt get a good look at that.
I could ony hope it was the flywheel.
Old Mar 5, 2004 | 07:21 PM
StreetStalkerZ's Avatar
Pull the window cover on the bell houseing and look to see if you had a converter bolt to back out. I threw 2 of them one day on the dyno and it was a scarey sight lol. If it is then it will be easy to put back in since the tranny can be put into N and roll the converter until you have checked them all or replaced them. If it's not that then you might have cracked the flexplate.
