footbrake RPM with a Yank SS3600*******
What can you footbrake rpm with your ss3600 before your tires break loose and did you have to tune your trans. after you installed your converter?
1 Post
Mines a TCI Super Streetfighter and I make it to about 2500-2600 before the 4.30 rear starts turning... Was just wondering this same thing myself. Thanks for posting the question
Agreed. All cars are not the same, some react differently than others once a TC is installed. I personally didn't need a tune once my TC was installed when I had a stock 4l60e, all I needed was a trans cooler. Surely a base tune wouldn't hurt anything for those of you who are **** about having a tune.
Restricted User
What are your guyses shift extension with the yank ss3600 converter? The I drove the other day dropped to 5k exactly and it shifted at 6500 rpm. I think my shift extension would be just as high if I was shifting at 6500 rpm
for what its worth...
Yank PY3600... built as a 5000 stall
Footbrake to 2500/2700 ish before my brakes wont hold it any more and I start to roll..
Shift at 6900... RPM Drops about 1200 rpm between shifts on my 2-3 which is my biggest gear split..everything else is right at 1000rpm for me.
Driving a TCI 6x
Driving a TCI 6x
1 Post
Having not thought of that, and if I understand correctly, were I to change from a 4.30:1 rear ratio to say a 3.73:1, I might make 3000 or so rpm before my rear starts moving on brakes? Thanks for bringing this up.
