what converter?
Old Sep 17, 2011 | 07:53 PM
camarorat's Avatar
Default what converter?
I have a 402 pumping out 470 HP through a 460LE with a 3200 vig converter. I am adding a 100 shot of nitrous what stall converter should I go with? car goes 11.14 @ 123 MPH N/A. weight is 3550, 390 gear.
Old Sep 17, 2011 | 07:54 PM
Fbodyjunkie06's Avatar
FTI all the way.
Old Sep 17, 2011 | 08:00 PM
camarorat's Avatar
They built the trans which is performing great, but what stall. I'm thinking 3200 is to low.
Old Sep 17, 2011 | 09:00 PM
Rhino79's Avatar
With nitrous you will want a lil tighter converter as the spray will loosen it up. You could run a looser one, don't know if it would be worth spending the dough though.
Old Sep 17, 2011 | 10:57 PM
01ssreda4's Avatar
I would talk your combo over with the converter manufacturers and see what they think. Yank, Circle D, FTI, or PTC would all be good choices IMO.
Old Sep 18, 2011 | 03:43 AM
Ask greg, he talked me out of going bigger than my 3800 as it really wasn't needed with my turbo spooling where it does.
I'd say 3600-3800, but you can go bigger if the converter is done as a power added convertor. When you hear people say oh my 4000 stall blew through after adding nitrous, is because the converter was never meant to see a power adder to begin with.
Old Sep 18, 2011 | 07:24 AM
camarorat's Avatar
Yea, I was using this converter with my stock LS1 running 13's. I think I need a different stall after reading some of these cars running 1.2, 1.3, 1.4 60's with way less HP and Tq than I have. Now I have the dilemma that if I get a converter that performs N/A will it perform with the N2O. I guess talking to a rep from one of the companies listed above would be the best advice.
Old Sep 19, 2011 | 12:52 PM
SuperSlow02's Avatar
Talk to Greg, he will get you lined out
Old Sep 21, 2011 | 05:58 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
camarorat, Give me a call at 1-866-726-8358 and we will design a converter to work with your combo. We have cnc machined stators to work with nitrous and yet get the stall desired.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
