Circle D - Cool Updates
Old Oct 20, 2011 | 12:41 PM
Circle-D's Avatar
Default Circle D - Cool Updates
Wanted to let you guys know of some of the improvements we are doing to our converters. First is our upgraded impeller hubs on the 4L60. These have been a problem in the industry for cracking and possibly causing pump problems in the transmissions. We have an upgraded hub that has had spectacular results, zero failures with over a year of use. Not saying it is bullet proof, but it is about as close as we can get. We started using it on our flagship multi disk and have now transitioned it to our complete 4L60 line, LT or LS, single or multi. This upgrade has been in place for about 6 months. Some of the other small improvements are new specs for internal clearances to make sure the hub fully engages on the pump rotor and maxing out the overall height to hopefully eliminate the need for shims. As always, any questions just ask....
Chris
Old Oct 20, 2011 | 08:07 PM
CoolAid's Avatar
Making a great converter even greater is muy bueno. Good work.
Old Oct 23, 2011 | 12:32 AM
TXZ28LS1's Avatar
Impressed with my Circle D 5C also..
Old Oct 23, 2011 | 07:19 PM
Circle-D's Avatar
Thanks guys, appreciate the kudos... This is an often overlooked failure on the 60e converters. Upgrading to the newer HD impeller hub is a huge improvement in durability. If the thinner hub cracks it can start leaking and eventually take out the trans pump.
Chris
Old Oct 24, 2011 | 07:26 PM
David Q's Avatar
Chris,
So what should all of us older converter owners do? Do we need to upgrade? Can you fix the problem before its too late or should we even worry? Everything seems to be working great.
Old Oct 24, 2011 | 07:31 PM
lady3bglover's Avatar
Ha.. Prob with my PI and the hub had to be replaced by a local shop down here Chris... I will keep this in mind.
Old Oct 24, 2011 | 09:16 PM
Circle-D's Avatar
Originally Posted by David Q
Chris,
The failure rate is not overwhelming, so you are probably ok. Our goal at CDS is zero converter failures. We are always working on something new and improved and eliminating the weak links. The intent was not to scare you on an older design. Just a update on our newer stuff....
Chris
