Are the flexplate-convert bolts threadlocked?
Old Oct 29, 2011 | 08:37 PM
siggyfreud's Avatar
Default Are the flexplate-convert bolts threadlocked?
Hey all,
Trying to separate my engine from the transmission. First off, I was a bit peeved to see that the flexplate/converter bolts are hex heads lol, as I just moved and had to finally purchase my own set of tools. I did have a hex head big enough, but can't really get much torque on these things.
Are these bolts threadlocked? Should I get a propane torch to heat them a bit? Any advice on budging these things. This is a 90k mile pullout from a WS6, going into a 68 Camaro.
Old Oct 30, 2011 | 01:25 AM
siggyfreud's Avatar
Forgot to mention (like an idiot) . . .
It's an LS1/4L60E
Old Oct 30, 2011 | 01:27 AM
01ssreda4's Avatar
I would assume they are. Heating them wouldn't hurt your situation.
Old Oct 30, 2011 | 05:22 PM
chrs1313's Avatar
gonna need a breaker bar or tq wrench to pop them lose...
Chris
Old Oct 30, 2011 | 05:42 PM
11SECSS's Avatar
I'm pretty sure they are and I always use some blue loctite when reinstalling them.They are though to get to break loose but I thought they where also a 15mm head on them also atleast mine are.
Old Oct 30, 2011 | 06:39 PM
senicalj4579's Avatar
Probably and yes a breaker bar. Thats what I used and I didnt need any heat on the bolts.
Old Oct 30, 2011 | 10:18 PM
NVR_SPDS's Avatar
If at first you dont succeed, get a bigger wrench!! I use loctite on mine, and have had the trans in and out a few times without issue.
Old Oct 31, 2011 | 06:05 AM
blk/slvr02ss's Avatar
If Heat or a Breaker bar dont work take a pointed Chisel and a big hammer and hit the coner of the Nut to break them loose it always works for me !
