transcooler
Old Nov 17, 2011 | 07:39 PM
JcsBlk98z28's Avatar
Default transcooler
What transcooler should i run with a 3600 stall?
I noticed b&m has a 13000 btu and a 14400 btu but I have no clue what the difference is?
Thanks
Old Nov 17, 2011 | 07:51 PM
senicalj4579's Avatar
Get the biggest one you can fit.
Old Nov 17, 2011 | 08:17 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
And if u want to get it even cooler don't put it inline with the stocker.
Old Nov 17, 2011 | 09:24 PM
^ Do you mean dont hook the lines up to the radiator just straight to the cooler?
Old Nov 17, 2011 | 10:17 PM
LS6427's Avatar
Cancel the stock cooler...it sucks. Just run an aftermarket cooler.
I run dual coolers....they do great.
Old Nov 17, 2011 | 10:42 PM
Yea forget the stock cooler.
FWIW I ran 2 coolers at one time and it really didnt change anything. I run 1 cooler now and it keeps the same temp as strange as it sounds.
Old Nov 17, 2011 | 11:20 PM
Got it thanks im going to order the 14400 btu.
What cooler are yall running?
Old Nov 20, 2011 | 09:03 AM
pancho toco loco's Avatar
If I remember the part number correctly I run a tru-cool #4590. I believe it was 12 x 11 x 1 1/2 thick . I liked it b/c its the biggest I could fit and its also a stacked plate thats
1 1/2 thick. Oh its also a Low pressure drop cooler.
Old Nov 20, 2011 | 10:11 AM
1lejohn's Avatar
if you plan on driving the car in cold cold weather then leave the stock cooler in line it helps preheat the fluid. I don't run one( stock cooler) but live in Texas. Even so my temps take along time to reach 180-200 in chilly weather say 40's-60's. At freeway speeds it will not even reach 160 while cruising in those temps. It does work great in the summer and at the track. Just a thought.
