View Poll Results: What Should i do?
Rebuild the Trans
2
40.00%
Swap In a 6 Speed
1
20.00%
Flush the Fluid
0
0%
Get a 4l80E
2
40.00%
Voters: 5. You may not vote on this poll
at a changing point.. which should i do?
Old Dec 8, 2011 | 04:11 AM
cavrron14's Avatar
Default at a changing point.. which should i do?
well recently my trans (4l60E) has been having hard 1-2 shifts but now it is starting to slip when it is freshly fired up badly to get my car moving in reverse, i had to get to 3K RPM to get her to budge. after she warmed up, all is fine, but still have that problem. i can take my guess that is a sure sign the trans is on her way out. so the question i have is simple. should i rebuild her, swap her for a 6 speed, or just flush the trans and see if it helps?
Old Dec 8, 2011 | 05:02 AM
BOBS99SS's Avatar
Captain Double Post
what do you do with the car, the cost of 6 speeds have gone sky high, so if your on a budget a rebuild might be a better idea, but even some rebuilds cost.there is not enough info for me to tell you anything
Old Dec 8, 2011 | 06:09 AM
cavrron14's Avatar
i mostly have it as a DD but i do quite a bit of canyon driving, and the occasional launch at a light from time to time :p if i opt to rebuild, i will be doing it myself, and make the mess on my table. on a side note, is there a bellhousing for the 5 speed from the V6 that will bolt up to the LSx ? <----n00b question, i know.
Sarg's Avatar
Not sure about your plans or set up, but what about a 4L80E swap? Some can be had for pretty cheap!
Old Dec 8, 2011 | 06:20 AM
Vince B's Avatar
Moderator
How does the trans move if freshly fired up and trying to go forward first? Also what mods do you have done to your car and what do you plan on doing with it?
Old Dec 8, 2011 | 10:00 AM
cavrron14's Avatar
about the same forward. and mods none other than intake and exhaust, but am planning on going boosted
Old Dec 9, 2011 | 09:00 PM
arock24's Avatar
4l80e
Old Dec 9, 2011 | 09:17 PM
ANTICOP RAM AIR's Avatar
PM "01ssreda4", hes a mod on here and has changed many minds in regard to the performance of an automatic... ask him about your issue...
Old Dec 9, 2011 | 09:31 PM
Sarg's Avatar
Hoping to take my little 4L60E into the low 9's, but if I had it to do over I probably would have done a 4L80E.
