What to expect after 3600 stall install
Old Nov 16, 2012 | 07:51 PM
  #41
Kristofer68ss's Avatar
just went through my emails.
for my needs, dave recommends a 3200 with a good tune.
Old Nov 17, 2012 | 10:15 AM
  #42
mjs1012's Avatar
Depending on how much you plan on spraying the car will play a big factor in your decision. If you are spraying often the 3200 would probably be better because it will flash higher in spray, but if its once in a while the 3600 should be fine and good n/a manners. I run the ss3600 and love it with my bolt on car. Can't go wrong with either tho.
Old Nov 17, 2012 | 11:35 AM
  #43
keith102371's Avatar
Originally Posted by optiplex
quick question guys. I have a Vig 4400 and i feel the same way that
TwitchZ28 feels about his stall. Everything he said is pretty much more or less the same thing that i have noticed and hate about my stall. Now, my question is, ive heard that Vig and other quality stall companies offer a one time free Re-stall. what do i have to do to get it restalled to a 3600 or so? Do i contact them and send it in? and do i need to have the recipt? Ive had this stall for about 4-5 years, unfortunality, the trans went out not long after i put it in so the stall only has less than 3k miles...Thanks
you can send it back and they will restall and rebuild it for like 260 I believe, I called them about 3 weeks ago, great people.
Old Nov 17, 2012 | 02:37 PM
  #44
sabersaw30's Avatar
I have a fti 3600 with a 1.7 str most 3600 or 4000 converters have a 2.3 to 2.5 str which is loose. Try and find a converter with a lower str and you will be happy.You will have good take off and good top end.My buddy has a new 6 speed 5.0 we was playing around up top and still run up to 145mph no problem.Did not loose no ground whatsoever.I really thought he would get away from me up top with my converter but I stayed right beside him.He runs 12.60 at 114mph.Always remember drag racing high str street racing lower str.
Old Nov 17, 2012 | 03:32 PM
  #45
sabersaw30's Avatar
A must read before you buy a converter. http://www.ls1gto.com/forums/showthread.php?t=349786
