What to expect after 3600 stall install
Old Dec 25, 2011 | 09:47 PM
01wss6's Avatar
Default What to expect after 3600 stall install
I have a 3600 vig stall and am about to install it in my stock 4l60e. Just wondering what to expect after the install.
Old Dec 25, 2011 | 10:04 PM
BAMALS1's Avatar
Lots more fun! If you go to the track 4-5 tenth E.T. reduction You will like it i'm certain.
Old Dec 25, 2011 | 10:10 PM
01wss6's Avatar
cool is the trans going to hold up for a while or is it going to go out shortly after
Old Dec 25, 2011 | 10:28 PM
01ssreda4's Avatar
Gonna feel like driving through mud at first, like the car doesn't wanna go. But when you get near the stall speed it will start to push the car really well.
Old Dec 25, 2011 | 11:21 PM
01wss6's Avatar
are a lot of people running stalls in their stock transmissions or are they rebuilding them first? thanks for the replies
Old Dec 25, 2011 | 11:24 PM
H82ZULOSE's Avatar
i had mine rebuilt and installed a yank ss3600 and it improved everything. you will have zero hesitation when you hit the gas. Just make sure your holding on and going straight.
Old Dec 26, 2011 | 12:20 AM
01ssreda4's Avatar
Ran a 3200 and Yank 4k in a stock 100k trans.
Old Dec 26, 2011 | 12:23 AM
projectX's Avatar
Depends on mileage for rebuild if your lower I wouldn't worry just get a good tranny cooler. As for what to expect - it will makes the car pull a lot harder.
Old Dec 26, 2011 | 06:49 AM
senicalj4579's Avatar
Expect to beat up on cars with more power at stop lights. You better get some stickier tires if you really wanna take advantage of the stall. Even from a highway roll the car will improve. Mine did anyway.
The driving through mud feeling just dosent exist anymore but It just takes a little more throttle to get the car moving during normal driving than it did with the stock stall. Its really not a big deal at all. You will love the performance.
The car improved...
.212 in the 60'
.463 and 1.28 mph in the 1/8 mile
.551 and 2.06 mph in the 1/4 mile
I love the fact I gained 2mph from a stall that even my tuner said I would most likely lose mph in the 1/4. Not bad gains huh?
I installed this last march and put about 12k on it. Im guessing 20-30 track passes with tons of wot on the street. The trans is stock with almost 105k on it now. It runs great knock on wood.
Old Dec 26, 2011 | 10:10 AM
Blue85350's Avatar
Expect to have to figure out how to drive the car again. And tires don't stand a chance anymore.
Old Dec 26, 2011 | 10:41 AM
NVR_SPDS's Avatar
Run a good cooler, and your trans should be ok. Im running an SS3600 with my FLT trans, and it HATES my back tires!! I LOVE driving with this stall.
Old Dec 26, 2011 | 11:31 AM
01wss6's Avatar
Thanks for all the replies I'm getting this stall in real soon!!!
Old Dec 27, 2011 | 09:17 AM
thunderstruck507's Avatar
Street tires are about useless. I can only get junk all seasons in 295/50r15 so anything close to half throttle from a stop will make it spin.
Old Jan 6, 2012 | 04:09 PM
evilz99's Avatar
Nice. I am about to pit my 3600 stall in to. So I am also glad to read all these comments.
Old Jan 6, 2012 | 04:33 PM
You will never want stock converter junk again.
Old Jan 6, 2012 | 05:27 PM
LS-ONE_DAY's Avatar
The car improved...
.212 in the 60'
Do you have a Yank SS3600?
I am thinking somewhere between a 3200-3600 for myself either Yank or CD, problem is that while I want a 3600 the cams I am looking at are better at midrange and ramp up faster so I don't want to lose useable power by going with a higher stall. My DD has a little issue where at a light when it turns green I'll press the gas and the car doesn't want to move sometimes until I add pressure to the pedal, I look at it as training for when the new TC is purchases for the Formula
Old Jan 11, 2012 | 06:03 PM
McNasty's Avatar
With a bolt on car and a stall, just exhaust, intake, etc, is it neccessary to have it tuned? I'd rather not tune it until I throw my heads and cam on, but if it needs a tune then I'll just throw everything on at once if that makes sense, no need to pay for 2 tunes when one is going on shortly after the other. Just wanted to try to drive the car to make sure everything goes smoothly with the stall before I put the h/c and possibly have more issues than what I want to deal with at once.
Old Jan 11, 2012 | 09:41 PM
sweet99ss's Avatar
It depends on where your rev limiter is set and how high of a stall speed converter you get. The converter will likely make you hit rev limiter like mine did so you will have to get retune. It will not hurt to drive it easy on your stock tune though.
Old Jan 26, 2012 | 10:47 PM
evilz99's Avatar
wow just put my revmax 3600 stall in the other day and LOVE it you guys were right tire fryer!
Old Jan 28, 2012 | 04:57 PM
blk/slvr02ss's Avatar
I would just change the fluid and a good tranny cooler and u will b good to go !!!
