4L80E Limp Mode possible causes?
Below is a log of parameters I ran using my trans config, something it showed was ignitino voltage was 11.0 V.
EDIT: For some reason I can't load my Config?? BUT force motor duty cylce is 4.7%, Force motor current is 0%, Line pressure 90%, Trans shift mode is Normal D2
It shows first gear when instantly when the car is running (like it should), its too wet to drive so I will confirm in the morning.
looks like input and output rpms match perfectly (Is this normal)?
BTW ignition voltage jumped to 13.00V.
Sure hope I still have good news in the morning.
Big thanks to all that helped, I really appreciate it. Stay TUNE
