4L80E Limp Mode possible causes?
Old Dec 26, 2011 | 06:00 PM
T/A KID's Avatar
Default 4L80E Limp Mode possible causes?
I am having a heck of a time getting my 4L80E to work with my LS1 ECU, and I just want to see if anyoneone has ideas of experience with this.
This is what I have checked
Power from ECU to trans plug
Power from trans plug to solenoids
Varified Solenoid A and B are working and TCC is getting power
Hp tuners shows "correct 4L80E segment swap" no way for me to varify.
EFI connections harness is correct Pin to ECU
NO DTC's reported even when trans plug and Speed sensors unplugged
Trans worked prior to LS1 ECU (TCI box), trans fail from a few feet snapping a small piece of the bellhousing when swapping to a PY3600, which was an easy fix and VERY doubtfoul it hurt any internals.
I verified in my hp tuners scan that the trans stays in second gear constantly (limp mode) I don't know what else to check. ANY HELP IS APPRECIATED.
BTW I called and talked to Gilbert at ACE transmissions (vendor here) and even though he doesn't know me from Adam he helped me and that speaks volumes about him. If I need work on this thing in the future he may be the one I call.
Old Dec 26, 2011 | 06:12 PM
Jake's Performance's Avatar
It is probably an easier issue to solve over the phone for sure.
Can you command any shifts with HPtuners?
Old Dec 26, 2011 | 06:19 PM
T/A KID's Avatar
Jake you got a number, you can PM me it, or I can call you in the morn.
I haven't tried to command shifts in the hp tuners software, but when I attempt to manually put it into a gear still nothing, just 2nd.
I appreciate your response.
Old Dec 26, 2011 | 07:04 PM
I'll try to pm it in a bit. Gonna be a bit busy in the am taking my son to surgery. Meanwhile try to command a shift in the test section of HPTuners. Have you tried to ohm the solenoid control wires from the pcm to the trans connector?
Old Dec 26, 2011 | 08:43 PM
T/A KID's Avatar
Hope your son is ok
I turned on the Solenoid 1-2 shift and then the 2-3 shift, didn't hear the solenoids or anything happen on the scanner (car just turned to run, not running). Then I commanded a gear from the scanners A4 select, It actually changed gears on the scanner, but I have no idea if it did in the trans.
I tested the solenoid power wires (A,B, TCC) in the pan, they are getting 10.8 volts in the run position, they would be 12 when running Im sure. My friend who is a mechanic used his tool with me commanding the solenoids and said they are working properly.
So technically I haven't tested ECU to trans connector but since the trans wires have power I would think there good?
Old Dec 26, 2011 | 09:34 PM
The solenoid command wires (A&B) are ground, not power. You will see power on them that is feeding through the solenoids. If you disconnect the main connector at the trans they will only show ground when commanded.
Old Dec 26, 2011 | 10:48 PM
T/A KID's Avatar
Jake I tested the wires on the Solenoids when I had the main plug connected (each solenoid has 2 wires), I just used some reference material on here and checked the voltage. I will call you tomarrow if thats ok, but what do you think I should try next.
I emailed Hp tuners support, but they are on Vaction till the beginning of the year. I hope to have someon look at my 4L80E segment swap to make sure its find tomarrow. I have heard the 4L80E can be run on a 4L60E segment, but I don't know the pros/cons.
Old Jan 9, 2012 | 05:28 PM
T/A KID's Avatar
Update: Installed brand new GM 1-2 2-3 shift solenoids I can hear them click when commanding using the VCM controls, but upon key on the on position still shows second gear only. What is weird though is I can command different gears with the VCM control (hearing the solenoid click and watching the scanner gear change) and the gear changes.
I really thought this would fix the problems, any more ideas from anyone.
Could a faulty PCS (force motor) cause this second gear only mode??
Old Jan 9, 2012 | 05:51 PM
No PCS can't cause the issue unless the PCM sees it's dead and goes to default.
You aren't going to show anything but 2nd until you have pressure.
Old Jan 9, 2012 | 06:11 PM
T/A KID's Avatar
Jake thanks for the response, so you mean I need to put the pan back on with fluid and crank her up, THEN change gears? Max line pressure on my tune is 90 (stock) and it shows 90 on trans pressure since its in limp mode.
Old Jan 9, 2012 | 06:45 PM
Cam72aro's Avatar
Drive the car and command the shifts via hp tuners scanner. What are the codes set to in the trans diag? Engine diag? Post the tune file. Maybe I can look it over. I learned a lot from Jake and slow 67 as to what certain codes set to no error will do.
Old Jan 9, 2012 | 07:09 PM
T/A KID's Avatar
Below is my tune, doesn't show any trans codes (even when I unplug the trans connectors)
P.S. Thank you
File Type: hpt
Old Jan 9, 2012 | 08:19 PM
Cam72aro's Avatar
When I mean trouble codes set I mean in the tune. On engine dtc's under engine diagnostics po740 to 785 is set to ses enable and mil on second error in mine. Some of yours are set to no error. Mine would not shift out of first when in drive with a lot of the trans dtc's set to no error. I had to set them to ses enable and mil on second error. Look at really all the auto trans or vss dtc's and set them to report on second error.
Old Jan 9, 2012 | 08:21 PM
Cam72aro's Avatar
here is my tune if you want to review it. Look at the dtc's under engine diagnostics. Mine shifts all the gears in drive and works correctly.
File Type: hpt
Old Jan 9, 2012 | 08:27 PM
slow67's Avatar
Gingervitis Addict
P.S. Thank you
Set them to Mil on first error, if its set to 2nd error, it takes 2 key cycles.
Old Jan 9, 2012 | 08:32 PM
Cam72aro's Avatar
^^^^ This guy knows his ****. Mine works with it set like I have it on second error. but might change it to first error.
Old Jan 9, 2012 | 08:42 PM
T/A KID's Avatar
Jake told me Slow67 knows his ****, said that was the guy who figured out the 4l60E segment swap to work with the 4L80E.
Cam I will do a compare with yours and setup my Trans DTC's to be the same as yours.
EDIT or change them to mil on first error (thats how my SD tune is setup to fail MAF) thanks Slow
Old Jan 9, 2012 | 08:55 PM
T/A KID's Avatar
Ok got it done, for some reason I thought the DTC's were setup correctly (thats what I get for trusting my initial tune)
Really? This is interesting to me, when you say first gear was yours really stuck in 2nd gear limp mode?
EDIT: Something that I discovered was my performance option was set to "Class 2" which is initially for trucks tow/haul (my segment swap was from a 4X4) I just switched this to "NO Switch" (f-body). Doubt this would an issue, but getting up early to see if anything changes.
Old Jan 9, 2012 | 09:59 PM
Cam72aro's Avatar
It was first gear according to scanner and it felt like first. I could activate the shift to 2nd and third so I knew it was first.
Old Jan 10, 2012 | 01:06 PM
slow67's Avatar
Gingervitis Addict
Its only for the performance mode shift tables (aka tow/haul mode).
