What Trans cooler and Pan?
Old Jan 6, 2012 | 07:35 AM
evilz99's Avatar
Default What Trans cooler and Pan?
I just got my 3600 stall for my 99 camaro and I am curious Do I need a deeper pan and a cooler or should I just get a cooler? I was looking at the derale pan because it already has a hole tapped for a trans temp gauge. Also If I do not need the pan, Where do you guys install the trans temp gauge? Do you drill and tap the pan or is there a secret spot I do not know about?
Also I see a lot of people running the b & m coolers and the cheaper hayden coolers. I am dont race very often and mainly dd my car. I just dont wanna overkill the hell out of this and waste valuable money to go towards my cam.
Thanks in advance for all the help guys!!
Old Jan 6, 2012 | 07:41 AM
evilz99's Avatar
Also, if I should go with B&M, Which one should I get? There is like 100 of them
Old Jan 6, 2012 | 09:38 AM
KEVS98LS1's Avatar
I got the b&m pan and cooler. Be careful if ur lowered there is only 3 inches between the ground and the pan.lucky our roads here in tennessee are excellent.
Old Jan 6, 2012 | 02:24 PM
NVR_SPDS's Avatar
You dont NEED a pan, but it will help keep your trans cooler.
I would do a search on here, for the cooler question. There is a couple coolers from B&M that alot of people run, I just cant remember the number off hand. Im running a big tube and fin cooler on mine, but dont have a temp gauge yet.
Old Jan 6, 2012 | 04:02 PM
wreckwriter's Avatar
Some B&M pans have the temp sender hole too but its not mentioned in the descriptions on Summit and such. Check with B&M
Old Jan 6, 2012 | 11:37 PM
01ssreda4's Avatar
B+M 70274 and a stock pan.
Old Jan 6, 2012 | 11:52 PM
LS-ONE_DAY's Avatar
I was also looking at the 70274 but does it come with everything to install it or would I have to buy the mounting kit (80278) also?
Old Jan 7, 2012 | 12:51 AM
01ssreda4's Avatar
Comes with nothing but the cooler. The smaller 70264 is what I started with and it comes with a full install kit.
Old Jan 7, 2012 | 08:51 AM
LS-ONE_DAY's Avatar
I checked out the B&M site, I don't even think they produce the 70274 anyone, its still available online other places but they discontinued it I think which sucks because it has the best btu rating. I assume its best to just get the big one and be done with it, as long as it fits. Are there any fitment issues for the 70274? I for one still have AC in my car.
Old Jan 7, 2012 | 04:45 PM
01ssreda4's Avatar
It will fit but its tight. It will fit with AC.
Old Jan 7, 2012 | 04:56 PM
time3777's Avatar
I have a Yank ss3600 converter and Dave at Yank reccomended me to use the Hayden toc-oc1679. It works good for me here in the south.
Old Jan 7, 2012 | 05:39 PM
Blue85350's Avatar
I'm using a B&M 70264 with my ss3600, no temp. gauge but it seems to do the job.
Old Jan 7, 2012 | 10:40 PM
01ssreda4's Avatar
B+M coolers are made by Long Co. in Canada. They are sold under many brand names. If it looks like a B+M, but its some other brand, it's prolly one of Long's coolers. So, same quality.
