th400 dd questions
Old Mar 16, 2012 | 02:32 PM
  #61
javier1730's Avatar
Originally Posted by lsxTAlemy
whats your high way like. how tall are your tires...
A 28" tires with 4.10 I dont think will ne a problem at the 1/8, at least until you put that 6.0 with 300+ shot lol
Old Mar 16, 2012 | 02:46 PM
  #62
dkbmxer002's Avatar
i have 3.70's
Old Mar 19, 2012 | 07:01 AM
  #63
lsxTAlemy's Avatar
Originally Posted by dkbmxer002
i forget what the 325/50/15 mickeys are but thats what i run. highway with a 3600 non lock up stall it sat around 3500/3600rpm at 75ish if i remember correctly (i could be a lil off) only reason i think i cooked the trans is i didn't run a trans temp gauge i am sure i got it a lil too hot with all the abuse i gave it even on long road trips.
well i think i just cooked my th350 Friday, cruising on the high way ttops off old school Ferrari braking neck and when i get home car wouldn't move had. to rev 4k to get it moving in to the drive way. i think it was over heated next day drove pretty normal but lil slipping on first.
Old Mar 19, 2012 | 07:04 AM
  #64
lsxTAlemy's Avatar
lol yea i know. i think that the tire are 26 on my set up, i have 50s and there 26
Old Mar 19, 2012 | 09:51 AM
  #65
javier1730's Avatar
sucks to hear that bro, do you have a deep pan on the trans? trans temp gauge? aftermarket trans cooler?
Old Mar 19, 2012 | 12:31 PM
  #66
dkbmxer002's Avatar
trans temp gauge is a must. i am doing one soon.
Old Mar 19, 2012 | 12:34 PM
  #67
lsxTAlemy's Avatar
cooler yea, B&M 24000 BTU biggest one they have and i don't have pan or temp gauge. witch ill be getting this weekend. i was told that the planetary only holds 450 500 witch i should be around there with the 100 shot. i had some metal shaving so I'm going to have to be buying some in the near future. ill be taking it easy with it for some time.
palm beach race way is having a super chevy show i might be going this weekend
Old Mar 19, 2012 | 01:10 PM
  #68
javier1730's Avatar
I need to get a deep pan and a gauge too for mine.....ill be there from friday to sunday im still undecided if im gonna run the vett, are you racing?
Old Mar 19, 2012 | 01:15 PM
  #69
javier1730's Avatar
Yeah you definatly need one specially for street driving.
Old Mar 19, 2012 | 01:49 PM
  #70
lsxTAlemy's Avatar
i don't think so unless i trailer the t/a up there. i don't want to hurt the trans and have to tow it down. if anything i might just enter the show and call it a day there's a show and bracket racing right. never been to that event before. there was an even at county line this weekend too but i herd of it too late...
Old Mar 20, 2012 | 11:52 AM
  #71
lsxTAlemy's Avatar
Old Mar 21, 2012 | 08:50 AM
  #72
lsxTAlemy's Avatar
getting my trans brake in today and rebuilding the th350 so should i use it with the stock diff spraying out the gate not a really good idea huh?
Old Mar 21, 2012 | 04:14 PM
  #73
javier1730's Avatar
lol not out of the gate unless u wanna go back home with the 10 bolt in a plastic bag....good to hear you are rebuilding so quick, will you be ready for the weekend?
Old Mar 22, 2012 | 06:35 AM
  #74
lsxTAlemy's Avatar
yea but ill be completely broke. I'm going to try to make it out there even with out the car. i got the trans down last night and opened up. 2nd gear burnt out and pump is gone so i should have it back together today and back up tomorrow...
Old Mar 27, 2012 | 07:32 AM
  #75
lsxTAlemy's Avatar
well got the car up and running. i destroyed a needle bearing that goes on the on the tip of the pump and the tip of the pump too. so got new bearing pump and jw trans brake. rmvb
Old Mar 27, 2012 | 11:05 AM
  #76
javier1730's Avatar
are you doing the work or you got someone doing it for you?
Old Mar 27, 2012 | 11:14 AM
  #77
lsxTAlemy's Avatar
my uncle is a tranny tech
