To flush or not to flush!!
Otherwise you're stuck with whatever's in the TC,
cooler lines & trans body and only end up about 1/2 -
2/3 changed.
A trans flush usually consists of hooking up a trans flush machine, starting the car, and as the car is running the machine is "sucking" out the old fluid while pushing new fluid into the trans. The trans flush has the fluid going the same direction as normal operation. I just don't see how that sprays the garbage in the filter back into the trans, unless somehow the flow of ATF was reversed through the trans.
FWIW, I have flushed mine with good results. We also flush and average of 10-15 cars at the shop, and in the past year I have never had one come back.
Jeff
