New TH400 Auto Shift Transbrakes
Old Jan 28, 2012 | 02:04 PM
Jake's Performance's Avatar
Default New TH400 Auto Shift Transbrakes
I get frequent requests for both an auto shift and forward pattern transbrake for the TH400. It's finally here, parts are machined. We will be building up a stock of the VBs this week.
Old Jan 28, 2012 | 07:17 PM
JZHeyde's Avatar
How much? details? does it retain engine braking?
Old Jan 28, 2012 | 08:43 PM
It retains engine braking and all normal auto shift features except detent/kickdown.
It will lock in manual low and can be manually or automatically shifted.
$250 per unit.
Old Jan 30, 2012 | 09:11 AM
69TA's Avatar
Let me get this straight you were able to make a
transbrake turbo 400 tranny that is not a manual valve body?
if so that's awesome, I always wanted one of those back in the day.
Old Jan 30, 2012 | 09:35 AM
Yes. Two different types.
Old Jan 30, 2012 | 04:20 PM
Fbodyjunkie06's Avatar
Man I really want one of these. I think when the 3.73 gear goes in and the tighter stall goes in I might end up with one of these if someone buys my TCI transbrake. Operation Street Fighter has commenced
Old Jan 30, 2012 | 07:17 PM
JZHeyde's Avatar
I would like to know what you mean by two different types? I am definitely thinking about ordering one of these.
Old Jan 30, 2012 | 07:57 PM
About a year ago I did the "Cheater" Th400 auto shift transbrake. It is an entirely hydraulic transbrake that works off the shifter to lock the transmission up in manual low gear.
So when the shifter is in LOW, the transmission will be locked up. You can do a burnout in 2nd or 3rd, stage the car, lock the shifter to manual low, and then throttle the engine to stall the converter up, as the light comes down, you bump the shifter to the 2nd gear position to release the transmission/transbrake to launch the car. It wil then auto shift to 2nd based on how you have the governor setup, and it will auto or you can manually shift to 3rd.
It's a very effective design, quick release, good exhaust, etc but you CANNOT accidentally engage low gear or you will be sliding to a stop.
A similar design was used on the Buick Grand Nationals called the Stageright.
Not quite as consistant as an electrically operated brake and the obvious safety concerns but a nice "cheat" in a class where a transbrake is not really allowed, because it has no electrical connection required at all it is very hard to detect.
The newest design uses the stock detent solenoid in the TH400 to electrically activate a transbrake, yet is still allows all the normal automatic features and full manual shifting except the normal kickdown function which most high powered cars don't use anyway.
