InstallUniversity TH400 conversion from M6: Follow along
Old Feb 20, 2012 | 09:41 AM
wizkid's Avatar
Install Director
Old Feb 20, 2012 | 12:26 PM
StraightTimeStirrups's Avatar
Originally Posted by wizkid
Dd you have a separate "arming" switch for the trans brake? Would hate to hit that button by accident in a parking lot.
It seems to me that there should be an arming switch somewhere as a safety. A single switch just seems to be an accident waiting to happen.
Joe
Old Feb 20, 2012 | 01:29 PM
wizkid's Avatar
Install Director
That is why I asked. I can see me bumping that button at any given moment. I will most likely wire in a Kill switch just to keep me honest. Besides, who isn't going to push that button pretending to be a jet fighter pilot driving down the road?
Old Feb 20, 2012 | 01:36 PM
TWS's Avatar
TWS
That button on the B&M looks a lot more apt to be engaged by accident than the one on my Cheetah shifter. Furthermore, just "bumping" the button for a split second won't do anything. You have to deliberately press it down. A light, split second "tap" when brushing it or bumping it by accident will not do anything. The button on the Cheetah is not on the top handle like on the B&M, so no reason to hit it while changing gears. I've had the car for 3 months now and it's not an issue in the slightest.
Old Feb 22, 2012 | 09:35 PM
lkn2run's Avatar
2 questions:1)why th400 over th350? 2)can someone give me a complete parts list to turn my m6 car to a th400? part numbers?
Old Feb 22, 2012 | 11:42 PM
A lot of it is personal parts choice but you will need:
1 tranny
2 correct weighted flex platefor LT1 if you have lt1
3 flex plate bolts
4 Torque Converter
5 torque converter bolts
6 crossmember and torque Arm replicator
7 driveshaft and yoke
8 trans cooler and lines
9 possible tune
10 Shifter
So far that's all I've needed but I'm not done
Old Feb 23, 2012 | 09:18 PM
wizkid's Avatar
Install Director
1) Strength.
2) Follow along on my web site as we go through the process of changing it out.
Old Mar 2, 2012 | 12:14 AM
NemeSS's Avatar
Any updates?
Old Mar 2, 2012 | 06:44 AM
wizkid's Avatar
Install Director
Not yet. Had to take a week off. Will test fit the TC next week.
I hope to release a pinion angle article as well in the next two weeks. I need to do some sketches.
Lots of side stories that need documenting before going further.
Old Mar 2, 2012 | 11:08 AM
NemeSS's Avatar
The side stories and quests detract from the main objective.
Old Jan 19, 2013 | 08:21 AM
wizkid's Avatar
Install Director
Sometimes being distracted only takes a three year old.
Shims are in and I am working on getting the next page up and published.
Old Jan 19, 2013 | 10:48 AM
  #32
wizkid's Avatar
Install Director
Flex plate install is published.
On to the starter removal and convertor installation doc's.
Old Feb 10, 2013 | 07:01 PM
  #33
wizkid's Avatar
Install Director
The transmission is in and the convertor is installed. The page is up and ready for review. Find any mistakes please let me know.
I also documented the maximum hole depths for transmission bell housing bolts.
TH400 Install Page
Old Feb 11, 2013 | 08:35 PM
  #34
wizkid's Avatar
Install Director
Starter is back in. Now to run down the correct trans mount for this installation.
FYI: I have the BMR transmission conversion cross member T56 --> TH400.
Finding a transmission mount locally has been all but impossible. I have ordered one from Madman and it should be here by Friday at the latest.
Catch up here
Old Feb 20, 2013 | 11:28 AM
  #35
wizkid's Avatar
Install Director
Transmission mount arrived! Thanks to Madman for the hookup after many failed attempts locally to get the correct mount. BMR cross member is in and the transmission jack has been pushed aside.
A 2.8/3.1 degree down angle was measured off the newly inserted Mark Williams tail shaft. The car was on a 0.2 degree down angle.
Factory LS1 spec is 2.6 - 2.9 down if I am not mistaken.
Updates coming soon.
Everything is documented to this point in the installation. We have to go over the above before we publish that page but it won't be long. :-)
Check out the progress pages here.
Old Feb 21, 2013 | 11:07 PM
  #36
93camaro_zzz's Avatar
Nice write-up! I will be undertaking this task in the next few weekends or so.
Old Feb 21, 2013 | 11:18 PM
  #37
wizkid's Avatar
Install Director
The trans mount page is up.
You will probably beat me. LOL
Thank you for the kind words. Hoses are next along with mounting the cooler.
Old Feb 25, 2013 | 09:26 AM
  #38
My6speedZ's Avatar
Why did you purchase the crossmember, I thought if you were running a 4" tail shaft the stock t-56 member would work. I'm researching an auto swap myself and this was the impression I was under.
Old Feb 25, 2013 | 07:29 PM
  #39
wizkid's Avatar
Install Director
That may indeed be the case but I do not know for sure. I knew for sure that if I purchased the BMR conversion crossmember it would work without question.
Maybe someone else can weigh in on this. It is probably covered in a sticky. I wonder if that is the case for the 350 but not the 400??
Old Mar 6, 2013 | 08:32 PM
  #40
wizkid's Avatar
Install Director
A location for the trans cooler has been determined.
The upper and lower plastic shroud under the air lid has been removed to make room for the trans cooler. Should have progress to report soon with the mounting.
If all goes well, a kit may be offered to simplify this process for everyone else wanting to do this.
