why stall ??
Old Feb 20, 2012 | 03:03 PM
custombluebird's Avatar
Default why stall ??
hi i have a question noone really answered it but why do i have to stall my trans am if i cam and head it i dont race alot??
Old Feb 20, 2012 | 10:02 PM
junior98's Avatar
I was told that one HUGE reason is because if your engine is making too much power on the stock stall your car won't be able to come to a complete stop at red lights and such, it will continue to push through your brakes. lol get the stall, it improves your performance anyways.
Old Feb 20, 2012 | 10:07 PM
ilovechevy1's Avatar
this is true, I have (had) a nearly stock LS1 with a MILD!! cam, and it would'nt stand still at a redlight, and I had to mash hard on the brakes to keep it still. Get atleast a 3000 stall but if you really want to feel a blast in your ***, get a 4000 stall. Your car will drive and perform so much better with a stall. They are'nt that hard to put in and you can get them pretty cheap here on tech if you don't mind buying a used one.
Old Feb 21, 2012 | 01:10 PM
okay thank guys this really helped me out
Old Feb 21, 2012 | 01:15 PM
thunderstruck507's Avatar
Bigger cam usually means higher idle and less vacuum at a lower idle. Combine them and the engine is running at a high enough rpm to ride against the stock converters operating range and decrease in vacuum means you have to push the brakes harder to get the same force.
So the result is a car that wants to push itself through the braking force to move even when you are not on the throttle.
Old Feb 21, 2012 | 01:22 PM
ANTICOP RAM AIR's Avatar
ive heard of guys drilling a 1/16 hole in their tb blade to get it to idle but I would consider that a bullshit fix.... Im assuming there will be no tune either? Seems like a waste of effort to me....
Old Feb 21, 2012 | 07:51 PM
okay because im thinking for the tsp 228r or 224r or torquer v2 but im not sure which one to get with which stall now
Old Feb 21, 2012 | 08:34 PM
peterlawl84's Avatar
I went with a yank ss3600 and love it. Like mentioned already, if you dont stall, then it will "push thru the brakes". I held off on upgrading the stall when i first did the h&c and it was just a pain in the ***. I would at least go with a 3200 if you are concerned with mpg, I've heard of 4k on a DD, but thats too much of a hit on mpg for me, so I went with 3600
Old Feb 21, 2012 | 08:37 PM
senicalj4579's Avatar
Excellent stall. It put my car in the 11s stock internal
Old Feb 22, 2012 | 03:01 AM
ls1wallen's Avatar
I ran a 228R cam on the stock stall for a year. It SUCKED!!! It was a pig down low. You had to hold the brakes really hard to stop. backing up was a nightmare trying to keep it from dieing. I wish everyone on this forum could have drove it once. We wouldnt have people asking about doing a cam before a stall.
I now have a 4000 stall and very happy.
Old Feb 22, 2012 | 03:11 AM
lemons12's Avatar
It is a torque converter.
Old Feb 24, 2012 | 01:11 PM
1BAD98TA's Avatar
lol lemons... You hate "stall" and I hate "nawz".. all the guys I work with are always asking me about my NAWZ!! I would have thought after I corrected them 1000 times they would have learned but.. NO!! Another one is when they talk about my cars "motor".. I have told them a million times the Prius has a motor, my car has an engine!!
So I am just used to it being called a stall and now I try not to let it bother me...
Old Feb 24, 2012 | 01:12 PM
AZ2ENVY's Avatar
Because Racecar
Old Feb 24, 2012 | 02:04 PM
lemons12's Avatar
I'm right there with you! LOL
