TH400 Swap.....What yr TH400???
I am the beginning stages of a TH400 swap. I need to buy a Th400 and I am curious is there a certain year I should get or stay away from?
What about the tail shaft lengths? I read somewhere I needed a 4" tail shaft. Is this true?
Thank you
Thank you
i have two models for sale. chevy pattern. Ones a new TCI 212500 built for 750 hp, and ones an ATI max duty for the 1400whp boosted stuff that has been freshened after 7 passes, griner brake, 2.10 gear set. let me know if of these interest you. I have the th400/LS conversion cross member too, brand new.
Well I did alot of research today on the TH400 swap. I have a couple questions regarding the converter and spacer. I have a TCI flexplate (399753) that i am running now. So what converter and spacer do I need for this whole trans to bolt up. Thank you for any help...
