Transmission Troubles
Old Feb 27, 2012 | 04:26 PM
Chaos07's Avatar
Default Transmission Troubles
OK well guys help me out here, The original transmission woudlnt shift and the RPMS would just rise with the gas pedal down and would hardly move but had power in reverse. So i bought a lvl 2 Transmission from performabuilt and guess what SAME THING no power at all in drive but plent of tire squeeling power in reverse so we put a new speed sensor in and try it out NOTHING. I know it cant be the same thing with 2 transmissions. Have any of yall expiernced this problem before?
Old Feb 27, 2012 | 06:00 PM
Chaos07's Avatar
anyone ever have this?
Old Feb 27, 2012 | 09:12 PM
Chaos07's Avatar
The car is giving me the P0757 solenoid B stuck on, and is going into limp mode (3rd Gear)
Old Feb 27, 2012 | 10:09 PM
mrvedit's Avatar
Moderator
All the solenoids receive continuous +12V in the trans and are activated by the PCM providing each solenoid's unique connection to ground.
Based on what you have said and that two transmissions are unlikely to have the same electrical problem, either your wire harness to the transmission has at least one wire shorted to ground or the PCM is defective.
I would check the wire harness first for any pinched or abraded areas. However my gut feeling is that your PCM is defective and will need to be replaced. I would go for a 2002 PCM which is the latest what will work with your car.
But I'm no trans expert, so wait for other opinions.
Old Feb 27, 2012 | 10:15 PM
Chaos07's Avatar
I just had the pcm tuned from frost, im sure if it was defective he would have found it. But ya after searching the code seems to happen when going to a higher stall or come on at a random time. I was really hoping to have my car up and running again lol
Old Feb 27, 2012 | 10:44 PM
mrvedit's Avatar
Moderator
Unless the tuner actually tested on a car, this problem (shorted power transistor in the PCM) would not show up in the tuning process.
A good scanner, e.g. Hp Tuners or what your local trans shop has, can activate and test the shift solenoids. In a quiet area with engine off, you can hear the solenoids turn on and off. If this test is successful, then the PCM, wiring harness and shift solenoids are fine. Based on what you are saying, I think the test will fail and it will take more electrical checking to determine if its the wiring harness or the PCM.
I assume your trans is in limp mode (3rd gear) and you have a high stall converter; hence the RPMs rise without the car moving. It should move once you hit the stall rpm.
Old Feb 27, 2012 | 10:49 PM
Chaos07's Avatar
Yeah its in limp mode 3rd gear, im talking to performabuilt right now and they are helping me figure out whats wrong. Im also going to get frost to help me out too
Old Feb 28, 2012 | 04:30 AM
Vince B's Avatar
Moderator
Have the tests for the PO751 and the PO757 removed from the computer and you will be fine.
Old Feb 28, 2012 | 09:00 AM
Chaos07's Avatar
thats what i was thinking after reading the transmissions sticky, but would thsoe codes come up with a stock transmission too?
Old Feb 28, 2012 | 07:46 PM
Vince B's Avatar
Moderator
Those codes in most cases with a high stall converter should appear in your history if in fact this is your issue. In your case you got one of them. The computer does not know if the trans is stock or modified so to speak. It just knows that your factory parameters are not correct thus the code your getting. Get frost to delete the tests for the two codes I mentioned and you should be good to go. HTH Vince
Old Feb 28, 2012 | 08:32 PM
Chaos07's Avatar
its on ist way to him right now
Old Feb 29, 2012 | 07:42 PM
Chaos07's Avatar
o0k well frost and i talked and he has already turned off those codes. And after doing resarch the transmission isnt getting power. Where am i going to be looking to be fix this anyone know??
Old Mar 1, 2012 | 02:28 PM
Gilbert@Ace Racing's Avatar
There is a fuse in one of the panels near the left headlamp/fender in the engine compartment. Check those for a burned TCS or engine PCM fuse.
g
Old Mar 1, 2012 | 07:30 PM
Chaos07's Avatar
ive checked all the fuses and they are all good. No signs of burning out at all
Old Mar 1, 2012 | 10:10 PM
mrvedit's Avatar
Moderator
I recall a recent thread where the author insisted he had checked all the fuses, but after a week of trying everything, found a blown fuse after all.
Use a volt meter to check that you have +12V on both sides of the fuse and/or just replace it anyway.
Old Mar 1, 2012 | 10:15 PM
Chaos07's Avatar
ok ill do that in the morning, and see if thats it
Old Mar 2, 2012 | 09:39 AM
Chaos07's Avatar
ok i checked all the fuses and they are all good when the computer gets here today and its still messing up im going to take it to a speed shop here
Old Mar 2, 2012 | 07:56 PM
Chaos07's Avatar
Well the car is still giving me the trouble it's still getting stuck in 3rd. I'm going to end up just taking it to the speed shop and have them look at it
Old Mar 9, 2012 | 06:42 PM
Chaos07's Avatar
OK UPDATE!!! it was the computer that was messed up put a new one in it and it runs fine now
Old Mar 9, 2012 | 07:31 PM
mrvedit's Avatar
Moderator
Thanks for the update; glad you got it fixed and running again.
