Clip on the shift cable?
Old Mar 11, 2012 | 02:35 PM
LS1MUNN's Avatar
Default Clip on the shift cable?
So, I just finished my used engine swap to find that the car wont go into reverse or drive or anything. In my haynes manual it looks like there is a clip that adjusts the shift cable. And I am missing mine. I cant seem to find any online parts diagrams. Can anyone confirm this clip? Maybe have a part #?
Old Mar 14, 2012 | 12:38 AM
DopeFedZ's Avatar
Just used this link to adjust mine today. Im using my stock 4l60 cable on a 4l80. The gears were off on the shifter by alot and this quick adjustment fixed it.
http://shbox.com/trans/A4_trans_linkage.html
Old Mar 14, 2012 | 01:22 AM
01ssreda4's Avatar
All the clip does is retain the cable and prevents it from popping off while driving. It has nothing to do with adjustment.
Old Mar 14, 2012 | 01:34 AM
DopeFedZ's Avatar
There are two. The one you are talking about and a plastic one on the other side of the cable bracket you push it up and then the cable can be adjusted.
Old Mar 14, 2012 | 01:48 AM
01ssreda4's Avatar
Gotcha....
