Those with Tranny Coolers come on in..
Ok i have a new tranny cooler well thats not the problem, i have a coolant leak from there the old lines used to hook in to. Did yall plug up those holes or did you just leave them alone? Mine is leaking from the bottom one i think, and if yall did plug them up what did you use.
I bypasses the raidiator and the guy who did it didnt plug the feed line to it so i believe coolant is dripping out of there. can anyone help me out?
Well hmm its kinda hard to tell some parts look purple some look oragny so its hard to tell with the black lines. Im going to give it a few days and if its still leaking out ill have to find out where and fix it. The tranny has its own cooler and nothing is leaking from there, but the old ports on the radiator i do believe are leaking a bit i just dont know wha actually it is. Ive checked the coolant levels and they seem fine, and so does the Tranny fluid.
I left mine open, never had intentions of using it again. If I ever replace the radiator I'll buy an M6 LT1 unit. And no there shouldn't be anything dripping from the empty tank except residual fluid and that should stop after some driving time.
I guess there is a leak Somewhere then when I add coolant it doesnt take much to fill maybe a cup idk. And I did what performabuilt said and bypassed the radiator
I put mine on the inside of my radiator and connected it so when fluids came out of the factory on they would go directly into the trans cooler for some more cooling. I truthfully didn't have any problems. I think changing the plugs for the first time is alot more difficult.Check all your connections and take your time.
Its been said that people who live up north and drive their cars in cold weather should have it hooked up to the stock cooler so trans temps can get up to temp quicker.
Thats all I can tell you.
I live up north and drive mine as long as theres no snow, rain, or to much salt. My cooler is ran by itself (no stock cooler) havent seen any issues yet. I just let it warm up a little before driving.
Coldest iv ever seen my trans temp is 20'sf. Takes a while for it to get up to temp. I wait till its at least 40f before I drive it.
IDK man seems to be fine for me. Screw the stock trans fluid warmer lol
