Transgo = delayed 2-3? + MPH vs RPM upshift question
I recently had a trans built and a transgo shift kit was part of the build. When picking up the finished car/trans I was told that it did not want to shift on the 2-3 and was banging the limiter, most likely because the transgo kit requires the commanded 2-3 shift RPM to be much lower than the desired shift RPM. Has anyone heard of this? I was told to try commanding 6000 RPM's, since I wanted to shift at 6600 on the 2-3. Tried it, didn't work. Kept trying lower RPM's at the track and dropped it to as low as 5000 RPM's commanded, still didn't work and nailed the limiter at 6900.
Second question, meeting MPH requirements for WOT upshift. I read somewhere that you can just set the WOT MPH requirements at 0 and it will always meet the requirements and shift at the desired RPM. Any truth to that? I would try it, but the car is down after losing 4th gear. I've also been told that the MPH possibly has to be within a realistic range of the shift RPM ..not sure what to believe? Any help is appreciated!
On the really high hp ****, I have had to command 5800 wot to get 3rd by 6600rpm. A lot has to happen AFTER the solenoid ground comes off (command shift) and the actual SHIFT. The 2nd gear servo is pressured from the opposite side to RELEASE the band (on in 2 and 4) and at the same time pressure up and feed 3rd through the stator support and input drum, applying the 3/4 clutch.
I suspect a leak in your 3rd oil feed (a number of places), and if the clearance in the 3/4 pack is to great it will take longer to shift....this is how I can tell a 3/4 pack is giving up the ghost a pass or so b4 it's gone for good.
Suggest running it with a gauge on the trans to monitor pressure, and u could double-check the work done on the valve body if your builder is not used to the trans go hd2 kit.....
Moderator
