please help trans does nothing after motor swap
trans is full of fluid. gear shifter is working, torque converter is spining while car is runing. drive shaft is hooked up.
what do you guys think could be the problem?
if converter wasnt locked in all the way by some chance wouldnt it be leaking fluid or somthing???
im clueless....
https://ls1tech.com/forums/automatic...-anything.html
A trans shop can often fix this $60 in parts and 1-1/2 hour of labor, assuming you R&R the trans. If you haven't rebuilt a trans before, I wouldn't recommend trying it now because you won't recognize if anything else is broken. Just my opinion.
