pin travel
Old May 23, 2012 | 04:03 PM
mrvedit's Avatar
Moderator
Originally Posted by 98LS1driver
Got it out!! Measures out at 0.100 has 70 gonna try a .80 an see
See, cussing helps.
Yes, 0.100 is on the thick side. Try a .080.
Just finger tight two pump bolts for your first check; you don't want to torque them down if there is no endplay.
Old May 23, 2012 | 10:42 PM
98LS1driver's Avatar
got very little play feels like it did before i pulled it so im going to put the dial indicator on it in the morning thanks for your help!!
