pin travel
I'm not sure what else you are asking, but let me try:
As long as the pin fits in the 1/2 accumulator case, it should be fine.
After final assembly, with the pump in, you can adjust the servo so that the drum barely has enough slack to let the drum turn by hand. (I adjust it before putting the pump in, but that is harder to explain.)
In case you are interested, I have hundreds of my 4L60E photos here:
http://s1015.photobucket.com/albums/...L60E%20Rebuild
So, if it is 0 now, you need to correct that. There is a "selective" washer underneath the input shaft bearing. You need an assortment of them. I would start with a thin .080, measure endplay and then get a thicker washer to drop the endplay to very close to 0.015. If even a .080 has 0 endplay, likely something is not assembled correctly.
HOWEVER, a rebuild generally shouldn't change it by all that much. Therefore, I would first be sure that the area around the front planetary and sun shell is assembled correctly.
Please tell me exactly what reaction carrier, sun shell and bearings you used in this area. (I have experimented with every combination, which you can probably find in my pictures.)
I was just helping another LS1TECH member this week, and he had an improperly rebuilt pump - the new stator shaft was not pressed in all the way and he therefore had no endplay. Check that too.
Notice that the reaction carrier on the left has additional machining to hold a torrington bearing.
IIRC, the #70 selective washer is one of the thinner ones, perhaps around .085. (They go up to around .115)
So something appears to be wrong.
Here are some questions:
1. Is your reverse drum sitting in the same position as in my picture?
2. Did you remember the gasket between the case and the pump?
3. Did you replace the stator shaft on the pump or just reuse it?
4. Can you measure the selective washer thickness and post it?
Hopefully I or a more experienced person can help you from those answers.
1. Is your reverse drum sitting in the same position as in my picture? Yes check and double checked
2. Did you remember the gasket between the case and the pump? Yes have a new one
3. Did you replace the stator shaft on the pump or just reuse it? Reused
Going to measure tomorrow and post pics I must have been mistaken on the 70 mine doesn't have anything stamped on the selective washer and I cant pull it off my other trans has a 69 clearly stamped on it but not this one
The reason I asked about the stator shaft is that I just helped someone else here who had a rebuilt pump with new stator shaft; unfortunately it was not pressed in all the way and this resulted in no endplay. Replacing the stator shaft in the pump is not a do-it-home project; take it to a trans shop and double-check even their work.
While you have your trans open, have you checked the inside of your reverse drum to be sure there is no wear where the teflon seals run. The $100 for a new reverse drum is often a good idea; it also lets you run a wider band.
Try cussing or something.
my other trans had 69 stamped in it this one is blank what am I doing wrong
