Convert harness from 4l80e to 4l60e???
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Yes the title is correct. I bought a harness on here from someone that told me it was a 4l60e harness. And that it had no connectors missing. Both of those were false.
I tried searching for this info but every result was how to convert 4l60e to 4l80e. However I need 4l80e TO 4l60e.
I just bought a 2007 4l60e last week with 50k and just bought a trans crossmember for a 4l60e for my swap. So now I need to know if this is possible to do or what?
I assume with the correct connector and right pin# on the PCM connectors I could run new wires? Or just add wires to the 4l80e?
The PCM I got is a 99-00 based on the numbers off of it I looked up. And it is red/blue connectors for drive by cable throttle body.
red/blue doesnt always mean DBW TB.
As far as I know if its a 4L60 harness you can buy a new 4L80 pigtail from speartech. I'm not 100% sure but that might be the only difference harness wise between the 4L60 & 4L80. Hopefully someone else will chime in that has more hands on type experience.
All I know is from recent research as I'm lookin to go M6-A4 this winter.
Those of you that use 4l60e with your swap did you use the neutral safety switch???
After going through my harness I figured out what connector I was missing.
Missing this connector.
![](https://i1206.photobucket.com/albums/bb456/RELL88SS/DSCN0235-1-1.jpg)
But I ended up getting a 2007 4l60e that has this safety switch.
![](http://www.transmissioncenter.org/IMG_0676.JPG)
My Harness is setup for this switch.
Found one thread on here and just one person claimed that you don't even need it for a ls swap. So before I go ahead and buy a new connector and safety switch I wanna make sure.
They function the same, you should just use whichever one your harness is setup for.
I don't see how you could be missing one out of the two connectors, unless the harness was for a manual transmission and the other connector you are confusing with an o2 connector.
