Whats the REAL differences between a 375$ converter and a 700$ one?
Old 06-16-2012, 12:50 PM
JWStevens's Avatar
Originally Posted by ls1121
you pay extra for the name plate. Lol. It depends on what you want to do with your converter.... Cruise it or beat it.
I tried asking a reasonable question like this and after i deleted the first two posts i stopped responding to my 3rd post and moved on. You probably won't get a good answer here.
I bought revmax and could not be happier.
lmao!
Old 06-16-2012, 02:31 PM
transbird95's Avatar
My $500 fuddle converter 1.8 60'. hooking seemed just like a stock unit only slipped a little more. The new Yank SS4000 1.61 spinning really bad yet. Only other change was the tune. Just my experience, hope it helps.
Old 06-16-2012, 05:56 PM
ls1wallen's Avatar
I paid around 400 for mine. I beat the sh*t out of it. Its held up for over a year
Old 06-16-2012, 06:01 PM
senicalj4579's Avatar
I wouldnt buy a cheap converter or a used one. Just my opinion though.
Old 06-16-2012, 06:36 PM
SnIpEz's Avatar
Nothing wrong at all with a used converter, as long as you have it inspected, cleaned and verified.
Old 06-16-2012, 08:28 PM
mjs1012's Avatar
In retrospect would buying a used converter and having a shop go through it cost similar to what a new one would cost? Maybe a dumb question but I was just wondering.
Old 06-16-2012, 09:49 PM
bwkmaro's Avatar
i just put one in from edge and im in love its a 4k stall but still drives really nice i was very surprised. plus the lock up on it grabs much better than stock. feels more like a racecar than a slush box that cost me 550 and the customer service was great
Old 06-17-2012, 12:56 AM
SnIpEz's Avatar
Say you buy a used converter for $450, that normally costs $700. You pay maybe $45, give or take $10 or so, and have it all checked out and verified. You typically save at least $100 or more.
Old 06-17-2012, 06:48 AM
justin hover's Avatar
I won't be buying a used one, so that part of the conversation can be dropped. I just havent read any fail threads regarding a "cheap" converter (revmax) for instance, comparably to a yank,ss,ptc, ect. I DD with moderate abuse if the time calls for it but it's also babied as well. I do plan on a cam 2 yrs from now. Nittos and converter first...Just wanted to know if the cheaper ones fail often, or if they hold up as good as any others. FOR DD PURPOSES.. no drag/strip racing and no 500p for a few yrs anyways
Old 06-17-2012, 07:32 AM
LS-ONE_DAY's Avatar
Who the hell are you sending it to for a $45 check?? I checked the cost of cutting and cleaning a converter and all the companies, sponsors included, that I looked up were all at least $125 to check out a converter, unless its under warranty, then you get one free, but that may only apply to the original owner.
Old 06-17-2012, 10:36 AM
Blue85350's Avatar
My cut and clean in January was $125. Where can I get them done that cheap
Old 06-17-2012, 10:48 AM
  #32
mike13's Avatar
I would have no reservation buying a high dollar converter if the buy said he would send it down to the builder for cleaning/ inspection and you pay the difference if there is any for restall since it's opened up anyway.
Old 06-17-2012, 10:56 AM
  #33
JWStevens's Avatar
From what you just said, you won't hurt the cheapest converter Revmax makes. We have 3 of them. My DD's converter cost 350 and it has 20K miles on it and works fine. The other 2 have been 6.0x and should be in the 5's before the summer is out. I don't see how ANY converter could not do what little you're asking honestly. You can spend a ton of money but it sounds like your stock converter would do what you want, if it was a little looser.
Old 06-17-2012, 11:06 AM
  #34
heymoej's Avatar
By the time it was all said & done, cut & cleaning with shipping the converter there & back.
I think i paid a total of $200.......
had to do that twice.............. because somebodys trans would not stay together.
live & learn.
good luck!
Old 06-17-2012, 11:47 AM
  #35
Revmax's Avatar
This is a good post and I think we can bring some light to situation:
There is a ton of incorrect and missing knowledge that over time has accumulated on the internet about 245mm (9.5", 10" converters) and 258mm (10.5" converters) and where they come from and what goes into building them. The information below is FACT, this is not opinion or second hand info!
Any 245mm or 258mm converter REGARDLESS of who builds the converter, whether it be $300 or $1300 is based off a 4cyl or 6 cyl GM converter core. YES, all of you that have an EXPENSIVE converter have a "cavailer" converter core in your car, as do all of you who have a cheap converter. Now, the only parts that are reused from the core are the: Turbine, Impeller and Stator (all of these parts are significantly modified and reinforced), the rest of the converter is thrown away. Now, when a QUALITY converter builder makes you a converter, there are a ton of steps that transform the 245mm or 258mm core into a converter that CAN and WILL as you know hold the power and weight of your F Body.
We have thru extensive long term testing found that a billet cover and apply piston is not needed on cars with less than 500HP NA or shooting less than a 100 shot of NOS, this is our stage 3 converter... Now, if you are 500HP plus, turbo, S/C or shooting a large shot, then yes, a billet cover and piston and larger clutch (our stage 5 unit) are required or you WILL have a failure! This is especially true for the forced induction and NOS applications. The front cover will balloon in these applications which takes the internal bearings off of their centerline and allows the clutch piston to make contact with the clutch mating surface. Both of these issues will cause catastrophic converter failure!
Now, regardless of whether your converter has a billet cover, piston and larger clutch, or it is comparable to say our stage 3. Your converter was in its past life a 4cyl or 6cyl GM 245MM / 258MM FWD converter out of a 4T40E, 4T60, 4T60E or 4T65E transmission. It does not matter who the builder was or how much you paid, all 245mm and 258mm converters started out this way, PERIOD! There is not a converter company in the world currently making new aftermarket impellers or turbines for the 245mm or 258mm converter. The only difference between a billet converter( our stage 5) and say our stage 3 non billet are the: Front cover, clutch piston and clutch, the rest of the converter is exactly the same as a non billet converter!
Our shop is always open to any LS1TECH members and you are all welcome to stop by ANYTIME. We would be happy to show you the process from start to finish and give you a tour of our facility(some of you already have)! For those of you who cannot, here is how a converter is made, step by step:
Step 1. Converter core is split open, parts are fully washed, and parts not needed are discarded.
Step 2. (This separates the good converters from the rest) The turbine, and impeller are sent to a furnace brazer which adds copper material to strengthen the bond between the fins and the housing. After this is done, some converters will require that the fins be TIG stitch welded on the turbine and impeller.
Step 3. The turbine is put on a CNC lathe and the original turbine hub splines are removed. Then the mating surface is machined perfectly flat.
Step 4. The impeller is put on a CNC lathe and the original impeller hub is removed. Then the mating surface is machined perfectly flat.
Step 5. The 245mm stator is gutted and its internals are replaced with stronger components.
Step 6. A kevlar, carbon or woven carbon fiber clutch is bonded to the clutch piston. ( on our stage 5 units and other converters, this is a larger billet item with the lining already bonded)
Step 7. New turbines splines are welded into the turbine to mate up to the customers transmission.
Step 8. A new impeller hub is welded onto the impeller to mate up to the customers transmission.
Step 9. Impeller, turbines and stator choices are made and internal clearances are set to match the STR and stall desired by the customer. New Torrington bearings are installed, and new seals are inserted.
Step 10. Converter endplay is set by the technician, and is then seam welded together on a robotic welder.
Step 11. Runout is measured after welding.
Step 12. Converter is leak tested at 120PSI to make sure the welds penetrated and sealed.
Step 13. Computerized balancing, balances the converter to insure that it is vibration free.
Step 14. Paint
Step 15. The converter is shipped!
Old 06-17-2012, 11:51 AM
  #36
Revmax's Avatar
A little bit more info to aleve your anxiety about reusing a core from a smaller vehicle.
Outlaw cars (4-4.6 1/8 mile cars) run either a 245mm, 258mm or 265mm converter. The 265mm cores come from Cadillac STS and DTS's....
Pro Street, Super Street and some outlaw cars run 8" converters. Until 3 years ago all 8" converters came from OPEL cores from the 1960's and 1970's..... These units can be pushed to 2000HP.
Our turbo mustang dyno's at just over 1400HP and it runs a 245MM converter (billet cover of course)!
Old 06-17-2012, 05:19 PM
  #37
LS1121's Avatar
I was in your shop just before you became a Sponsor here and it was because of your OFFER to me to come and see the Process and your EXPLANATION of the process and Visual that convinced me to buy one of your converters. My car now has maybe a little over 400 hp andI could not be Happier.Thank You tom.
Old 06-17-2012, 09:14 PM
  #38
flywheel's Avatar
I'll be buying a Revmax soon for my 4l60E. Wonder if they have any specials going on?
Rick
Old 06-17-2012, 09:30 PM
  #39
Jake's Performance's Avatar
A "cheap" converter. i.e. a non-billet cover converter with a "V6" lockup disc works fine in the lower powered cars as RevMax stated and as I've stated here before and gotten slammed for.
The market has been conditioned by advertising to lead the consumer to believe they must have a billet cover unit.
There are two ways to look at this.
From a consumer point of view and from a business point of view.
A consumer will often try to save money and may want to buy a product that is broderline or not adequate for their needs because it is half the cost. On the other hand they may be willing to spend twice as much for peace of mind on something totally unnecessary for their use.
A business will want to overbuild their product so they can protect their product, reputation, and reduce comebacks.
We typically build transmissions for higher end stuff. I would say 85% of what we do is 800+ HP. So by default we sell mostly billet converters.
However the milder daily driven combos that make ~400 HP will do well with a non-billet converter.
An informed customer will know that they can't WOT lockup and they need to tune the PWM out as well as only lockup under light throttle cruise conditions. The converter will last YEARS under these conditions.
If the customer can get by with a budget deal but can afford the billet, go for the billet. It gives you room to grow later.
We pay $125 for a cut and clean. Elite doesn't see the invoices so I guess he thinks that sh*t is cheap!
Old 06-17-2012, 11:03 PM
  #40
SnIpEz's Avatar
For all those who posted after me, I'm just noticing what I typed, I meant to type $145. It was the price I assumed most people would pay a shop to do (give or take a few bucks depending on the shop). Now I feel like an idiot, but I will point out that the math I used was meant for assuming $145 or so off, so that should make a little more sense.
700 for new, 450 for used, spend 145 for clean, pay 600 all told, save 100 (or more)
Quick Reply: Whats the REAL differences between a 375$ converter and a 700$ one?
