Shift kit questions
Does this mean the 4L60e basically becomes a manual tranny?
What is torque management and do all stock cars have it?
Besides better shifting how else will it improve performance?
Does it have a big effect on daily driving?
Is there anything else I'll need to purchase for proper install?
Is there a significant difference between the TransGo kit and the B&M kit?
Sorry for so many questions but I'm a complete noob haha just trying to learn more about these cars and whats best for my car as far as mods go.
https://ls1tech.com/forums/automatic...d2-yes-no.html
https://ls1tech.com/forums/automatic...hift-kits.html
https://ls1tech.com/forums/automatic...shift-kit.html
To quickly answer your Qs:
It does not make it a manual tranny. Personally I did not install the "hold any gear" valve to prevent accidental overrev.
Torque management is when the ignition advance is reduced during the shift to reduce wear and soften the shift. It can be programmed out.
Read the threads; it will prolong the life of your trans.
Little effect on daily driving; just slightly firmer shifts.
It is not trivial to install and you may want to hire that out; figure about $250-$400 to install.
Avoid the B&M; its just a few parts to "bang" your gears which is fine for kids but will ruin your trans and drivetrain.
Since you say you are a trans "noob", I cannot recommend trying to install a shift kit yourself. While many here have done it successfully, others have made mistakes that are time consuming and/or expensive to fix. The transgo instructions can politely be called "terse".
Here is another very useful thread on the issue including the Transgo instructions:
https://ls1tech.com/forums/automatic...questions.html
Revgto answered your other question.
If you don't want the "Hold any gear" feature, leave out Step 5 on Page 2 of the instructions.
