shift points
Old Apr 3, 2004 | 12:55 PM
Tony Touch's Avatar
Default shift points
I have a 2000 ws6 a4 with 3.23 i have the hypertech powerprogrtamer. How many mph should i raise my 1-2 2-3 3-4 shifts for optimal quarter mile performance
Old Apr 3, 2004 | 09:09 PM
camaro98z28's Avatar
I have 3.73's and went 1-2 +4 , 2-3 +6, 3-4 + 14.
In your case would raise it only a little. I also have mine at a 6400rpm rev limiter
Old Apr 5, 2004 | 04:58 AM
Flals1's Avatar
What other mods do you have? I have the same gears and I have been wondering what shift points to use. How are your part throttle shifts? Did they improve any?
Old Apr 5, 2004 | 07:36 PM
chief455's Avatar
you are going to have to do this at the track to answer your question. every car/track/combo will be different. My bet was 1-2+3, 2-3+1, 3-4+1 but doen't matter cause the car is in 3 at the end of the quarter. I tried extending further like camaro98z28 and my car sowedd down. I have 3.73 also. When I had 3.23 the same points worked best for me.
go racing and change between runs. I suggest change one gear at a time to see each improvement.
Old Apr 8, 2004 | 05:22 AM
Flals1's Avatar
Thanks.
Old Apr 13, 2004 | 01:34 AM
BriancWS6's Avatar
If you don't have any stiffer valve springs I wouldn't suggest changing the rev limiter. Stock is at 6200. The stock cam flatlines at around 5200-5500 anyway. I bumped my shift points up 1mph on the 1-2 shift and 1mph on the 2-3 shift also. Anything higher and it would hit the rev limiter right before it shifted. An aftermarket cam and springs and you could up the shift points with good results I would say. Hope this helps, just my .02
Old Apr 13, 2004 | 02:17 AM
calongo_SS's Avatar
I agree, the factory rev limiter is right where it should be. Any higher and you start getting valve float. I have a freind who destroyed an engine doing this. I believe he had his limiter set at 6400 or 6500. It didnt take long either...
Old Apr 13, 2004 | 04:59 AM
Flals1's Avatar
Thanks for all the help. I set my Rev limiter at 6200rpm. I'll leave that alone. Now I need to work on the shift points. I just did a stall (2800) converter and it has really played hell with the shift points. I hit the rev limiter in 2nd-3rd shift. I guess ill need to back that one down.
Thanks,
