4L60 No First Gear
Old Jul 25, 2012 | 09:10 AM
Troy5061's Avatar
Default 4L60 No First Gear
What could cause a no 1st gear condition in a 4l60e? If I put it in "D" it will start off in 3rd and shift to 4th fine and the converter locks up fine, if I put it in 2nd it will start in 2nd gear and I can manually shift to "D" and 3rd, 4th, lockup all work. If I manually put it in 1st it starts in 2nd just like putting it in 2nd manually. Fluid looks good, NO codes.
Old Jul 25, 2012 | 10:56 AM
Sweet_SS's Avatar
Mine did this, but it was a 2nd gear issue. Mine would shift from 1st and skip to 3rd and then OD. The converter would lock up fine to. If I manually put the car into 2nd, it would still skip to 3rd. My 2nd gear band was destroyed
Old Jul 31, 2012 | 11:15 PM
bluchev's Avatar
swap out the solenoids
Old Aug 3, 2012 | 01:32 PM
Troy5061's Avatar
One of the accumlator ***** was mashed into the separator plate and wouldn't come out.
